SRS light still comes on after repair - BMW Forum - BimmerWerkz.com
Old 03-17-2006, 08:49 AM   #1 (permalink)
flandersmmm is an unknown quantity at this point
I had a local shop run the code after I was getting the SRS light on for the first 1 min after starting the car-then it goes off. Everyone knows this is probably a seat belt buckle. The code came back drivers side belt buckle, so I replaced it after disconnecting the battery as per Bentley book. Does this type of code fault require SRS reset after repair??? The light still comes on for a minute or 2.
flandersmmm is offline   Reply With Quote
Old 03-18-2006, 02:54 AM   #2 (permalink)
ex owner/admin
Furious's Avatar
yes
once a code is present , usually you need to reset for it to go away, that is if you truely got the proper code the first time and repaired the proper issue.
Desperately Need Your Help: BMW325i "Service Engine Soon" light problem CNMB250 3-Series (E46, E90) 4 12-19-2007 06:26 AM
2001 525i DSC light on after sttering wheel repair Excellence 5-Series (E12,E28, E34, E39, E60) 2 01-02-2004 10:12 AM
