| Take her to an independent Tech and get her coded and reset and that may cure the problem if not the coding should tell you what is going on, in my case I had to replace the clockspring (really, the clockspring, this is not a joke and the spring does not run the clock).
The coil in the steering colum that connects to the air bag, right? was it blinking a bunch times like mine? |
