| This is not a question anybody in here should answer. The airbag system is a very precise mechanism and you want it to do its job. Don't take the word of anyone in here if your life is going to depend on it.
If you have a doubt then I seriously advise having a qualified mechanic check the airbag system. Better safe then sorry.
The latch sensor will give this symptom if it is faulty. Replace the sensor and then look at the airbag system if that did not solve the issue. It would be irresponsible to give a definitive answer of 'yes, your airbag will deploy so don't worry'
