squealy brakes - BMW Forum - BimmerWerkz.com
Old 04-13-2006, 03:02 PM   #1 (permalink)
LYFE SUCK5
Ivan's Avatar
Car: 2008 Infiniti G35
Ivan has a brilliant futureIvan has a brilliant futureIvan has a brilliant futureIvan has a brilliant futureIvan has a brilliant futureIvan has a brilliant futureIvan has a brilliant futureIvan has a brilliant futureIvan has a brilliant futureIvan has a brilliant futureIvan has a brilliant future
Send a message via AIM to Ivan
squealy brakes
not a problem with the rotors or pads, i was told theyre just aftermarket pads and they squeal sometimes. i was also told there is something i could buy to spray on them to get them to stop squealing. does anyone know anything about this?
Ivan is offline   Reply With Quote
Old 04-13-2006, 05:02 PM   #2 (permalink)
325isBaby's Avatar
Car: 2005 330xi
it is common for aftermarket pads to squeel due to the metalic content being higher in aftermarket pads than in factory pads, the spray you are thinking of is sold at Napa (disc brake quite I believe it's called) it comes in a red can and you spray it on the non-braking side of the padbut BMW does not recomend the use of this spray, BMW suggests the use of Bostic on the back surface of the pad (the non-braking side) for squeels (I've done this many times at the dealership for squeels and it works)
Come see me at MySpace
Old 04-13-2006, 09:35 PM   #3 (permalink)
uber e36's Avatar
uber e36 is an unknown quantity at this point
Send a message via MSN to uber e36
What about buying #15 in this diagram: http://www.realoem.com/bmw/showparts...69&hg=34&fg=05
Click signature for pictures:
Need some Real Estate Advice? www.gracehomes.com
uber e36 is offline   Reply With Quote
Old 04-13-2006, 10:44 PM   #4 (permalink)
LYFE SUCK5
Ivan's Avatar
is bostic a spray also? and where can i get some? at the dealership?
Old 04-13-2006, 10:45 PM   #5 (permalink)
LYFE SUCK5
Ivan's Avatar
yeah possibly
thanks
Old 04-14-2006, 12:43 AM   #6 (permalink)
325isBaby's Avatar
Car: 2005 330xi
bostic is a paste (similar to anti-seeze) best place to buy it is Napa, Checker/Shucks/Kragen, any general auto store should carry it...
Old 04-14-2006, 01:58 AM   #7 (permalink)
LYFE SUCK5
Ivan's Avatar
thank you very much
Old 04-17-2006, 08:05 AM   #8 (permalink)
Science Roolz!
Car: 2011 Mazda2, 1990 Miata
anti-squeal lubricant my friend, put some of that on the contact points of your calipers
two little packets from autozone maybe like a dollar for two that should do it
2011 Mazda2
1990 Mazda Miata
Squeky Brakes ynotony 3-Series (E36) 2 07-21-2005 06:07 PM
Squeeling New Brakes Ljk619 3-Series (E46, E90) 6 07-08-2005 01:31 PM
Steering Shaking With And Without Hot Brakes zanick 3-Series (E46, E90) 3 10-26-2004 11:02 AM
do your brakes squeak? GnarlyCow 3-Series (E46, E90) 12 09-22-2004 08:03 PM
Smoking brakes? Pegasus 3-Series (E36) 21 09-16-2004 04:30 PM
