Squeaky steering wheel - BMW Forum - BimmerWerkz.com
Old 06-25-2004, 09:24 PM   #1 (permalink)
Stunnd65's Avatar
Stunnd65 is an unknown quantity at this point
I'm getting a little squeaking noise from the steering wheel. What's the best way to lubricate it, and where? I was thinking of WD-40, but I figured I'd ask before trying it.
Cashmere Beige Metallic '93 325i
Stunnd65 is offline   Reply With Quote
Old 06-25-2004, 09:26 PM   #2 (permalink)
mrjoshua's Avatar
mrjoshua is an unknown quantity at this point
Send a message via AIM to mrjoshua Send a message via Yahoo to mrjoshua
I have the same thing man I have not found a place where you could get access to spray anything in there. I hope someone knows cause it's about to drive me crazy.
mrjoshua is offline   Reply With Quote
Old 06-25-2004, 09:28 PM   #3 (permalink)
Been here a while.
97alpineM3's Avatar
Car: Blah
If I'm not mistaken... there are bearings inside of there... and some parts are packed with greise..... there are also a lot of electrical connections there too.... DO NOT SPRAY any liquid on there.... take it to a dealer.... let them deal with it..
1997 E36 M3 1990 E30 325i
Old 06-25-2004, 09:59 PM   #4 (permalink)
Stunnd65's Avatar
I'm glad I asked. Thanks!
Old 06-25-2004, 10:03 PM   #5 (permalink)
Been here a while.
97alpineM3's Avatar
Car: Blah
If you really want to take a look at it... there is one screw right underneath the stearing collum... take that out...(watch out the backing that holds the screw might fall out with it.. so grab that if it does... ) then pull the bottom piece out... and there are two plastic pieces right around the top part of the stearing collum that are snaped together.... just snap them apart... and it exposes the entire mechanical workings of the stearing collum... then you will see why I said not to spray that sucker...
Old 06-25-2004, 10:04 PM   #6 (permalink)
Been here a while.
97alpineM3's Avatar
Car: Blah
Again... then above procedure is very rough.. just a general gist of what to do... its fairly easy... but I didnt meantion.. that what I just said.. probably only applys to E36s.... I didnt see what you drove...
Old 06-28-2004, 12:10 PM   #7 (permalink)
Stunnd65's Avatar
Thanks. I'm quite paranoid about screwing something new up, so I'm just going to live with it for now since it's very minor. B)
Old 06-28-2004, 12:18 PM   #8 (permalink)
BlantonG13's Avatar
BlantonG13 is an unknown quantity at this point
Send a message via AIM to BlantonG13
he has a 95 325. He is posting in the E36 forum for a reason :nana
1996 318i
5 Speed Manual
Alpine CDA-7895 Head Unit
12" Alpine Type-R, sealed box
Infinity Kappa 4" 2-way speakers(rear)
Infinity Kappa 5.25" component speakers(front)
Debaffled airbox, K&N filter
Tracked Mud on carpets
Shampooed and cleaned carpets
BlantonG13 is offline   Reply With Quote
Old 06-28-2004, 02:01 PM   #9 (permalink)
Kevin325i's Avatar
Wait I've got an idea. What about talcum powder? Or one of those other powerders like graphite dust. If it doesn't conduct electricity it won't mess anything up. And it will help it move without the squeak. Just a thought.
Kevin
Kevin (President TBEA)
Old 06-28-2004, 03:15 PM   #10 (permalink)
I'm not sure about graphite powder, but graphite is usually a conductor.
Old 06-28-2004, 03:25 PM   #11 (permalink)
Kevin325i's Avatar
Try a sprinkle of talcum powder than, I wasn't sure about graphite. See if it helps.... I don't think it will harm anything, 2nd opinions?
Kevin
Old 06-28-2004, 04:33 PM   #12 (permalink)
Q_BMW's Avatar
Q_BMW is an unknown quantity at this point
Send a message via AIM to Q_BMW Send a message via MSN to Q_BMW
are you sure its not the coil spring in your steering wheel ? I had the same problem and the dealer said the coil spring in there needed to be changed.
<span style='font-size:15pt;line-height:100%'><span style='color:red'>JUST SOLD:</span> <span style='color:blue'>01 BMW 330i with Sport &amp; M Package(5sp)</span></span>
<span style='font-size:14pt;line-height:100%'><span style='color:blue'>Past:</span> <span style='color:red'>1996 BMW 328i</span></span>
<span style='font-size:14pt;line-height:100%'><a href='http://www.ofoto.com/BrowsePhotos.jsp?&collid=10038932107&page=1&sort_o rder=0' target='_blank'>PICTURES!!</a></span>
Q_BMW is offline   Reply With Quote
Old 06-28-2004, 07:00 PM   #13 (permalink)
wozza is an unknown quantity at this point
I had this problem. Disconnect the battery and leave for a good couple of hours (precaution for airbag sensor). Not sure which wheel you have but my airbag wheel has two torx bolts at the rear. Proceed with removing the wheel and line the wheel/steering column contact point with copper grease. Job done.
wozza is offline   Reply With Quote
Old 06-28-2004, 07:29 PM   #14 (permalink)
Been here a while.
97alpineM3's Avatar
Car: Blah
Sorry... but me no likey.... the poweder idea..... just doesnt seem right for some reason.... sorry...
Old 06-28-2004, 11:23 PM   #15 (permalink)
BlantonG13's Avatar
I would feel weird using talcum poweder...its like my car is having a sweaty foot problem...it is however an interesting idea that might just work. Do not use graphite because it is a conductor...a rather poor conductor compared to other metals, but it is a metal none the less.
1996 318i
5 Speed Manual
12&quot; Alpine Type-R, sealed box
Infinity Kappa 4&quot; 2-way speakers(rear)
Infinity Kappa 5.25&quot; component speakers(front)
Debaffled airbox, K&amp;N filter
Steering wheel noise on 325xi on right turn rms 3-Series (E46, E90) 1 10-10-2005 11:19 PM
Bmw M-technic 2 Leather Steering Wheel schneider252 OEM Parts 4 04-22-2005 10:34 PM
Steering Wheel Upgrade Options gmal 5-Series (E12,E28, E34, E39, E60) 0 10-28-2004 08:25 AM
E36 Steering Wheel MrTwisties 3-Series (E36) 6 07-23-2004 01:36 AM
Triangle 3 spoke Sport Steering wheel woobiee Classifieds Sell & Buy 11 10-03-2003 03:08 PM
