I wouldn't say anything is wrong so long as you use similar to stock size. I would only lower it if you are changing all 4. If you have ever noticed, most BMW lowering springs lower the back less than the front. So if you were to just put lower springs on the back, it would make the back a little lower than the front stock setup. It probably won't cause any problems, it just might look a little weird. BMWs stock already have a lower look to their stance. You should probably remain uniform in what you do.
I agree with Furious, take advantage of this to do some upgrades with performance parts in mind!
__________________ 1996 318i
5 Speed Manual
Alpine CDA-7895 Head Unit
12" Alpine Type-R, sealed box
Infinity Kappa 4" 2-way speakers(rear)
Infinity Kappa 5.25" component speakers(front)
Debaffled airbox, K&N filter
Tracked Mud on carpets
Shampooed and cleaned carpets
With new springs.... isnt it smart to upgrade the shocks/struts.... to compensate for the drop? Or is that a crazy rumor?
__________________ <span style='color:red'>- Conforti cold air intake
-Triflo exhaust
-Clear corners and tails
-Custom wheels
-Racing Dynamics stress bar
-UUC short shift kit
-Turnermotorsport Performance Chip
Soon to come - Zimmerman brakes, and suspension AND UMNITZA DDE IF I EVER GET THE GODDAMN MONEY </span>
A great way to upgrade your ride is to replace worn out or defective parts with "better than stock" ones. This way over time, your ride constantly improves.
great point Mark. I agree. It is definitely not a crazy rumor. Stock shocks can handle the drop to some degree, but have a much better chance of failure in a shorter amount of time. I would also recommend getting new shock/struts. Overall, it will just make your overall ride and handling that much better than the already superb handling of a BMW.
5 Speed Manual
i have noticed that with mine aswell back lower then front
also, eibach pro-kit says i won't need to update the suspension bits but i will at sometime update it just in case, but is it really going to hurt the original shocks if the lowering springs are put into my car used .
well i got eibachs on mine, and I believe that all bimmers get lowered this way. That is why there is a majority of bmw owners whom only lower the front end.
i think thats why with most springs you get a lower drop in the front... plus i noticed that too but i think its just decieving. Problem with new springs and original suspension is your stock shocks/struts werent designed to compensate for the drop which could result in bottoming out. Im sure you could most likely get away with it though, im not that familiar with the suspension so i might be wrong.
-Triflo exhaust
-Custom wheels
