spring shock input - BMW Forum - BimmerWerkz.com
post #1 of 8 (permalink) Old 07-13-2004, 06:31 PM Thread Starter
I should have an ass load of overtime over the next month. Since my car has 115K miles on it, it should be time for new springs and shocks. I have the sport suspension now, and love how the car sits low. I really want to keep that, but not go any lower, I bottom the car out enough as is. I also DO NOT want a stiffer ride. I drive this car to work every day, and want the smoothest ride possible.
What would should I get? I was thinking about bilstens and some spring with 1 1/2" of drop to them. Does anyone know how much the factory sport suspension is lowered compared to stock?
wulley1 is offline
post #2 of 8 (permalink) Old 07-13-2004, 09:45 PM
thekid's Avatar
thekid has a reputation beyond repute thekid has a reputation beyond repute thekid has a reputation beyond repute thekid has a reputation beyond repute thekid has a reputation beyond repute thekid has a reputation beyond repute thekid has a reputation beyond repute thekid has a reputation beyond repute thekid has a reputation beyond repute thekid has a reputation beyond repute thekid has a reputation beyond repute
I was in the same position as you when I started looking at my suspension. I wanted the ride to still be comfy and yet handle better for auto-x. You are going to have to compromise some where. The setup I have ended up with is Bilstien Touring shocks with bavauto.com springs. There is one problem with this setup. The Touring shocks aren't made for lowering springs, but the drop is less than 1 1/2" so I think its gonna be fine. If you go with the Bilstien sport springs the ride will most likely be too firm for you, since you still want stock ride quality. Even though my car rides like stock on good roads, once you get onto bad/not so good roads you can really start to feel it. Intersections that used to be just fine now throw the car every where, but all the city roads around here are horrible Hope this helps.
thekid is offline
post #3 of 8 (permalink) Old 07-13-2004, 10:07 PM
Bilstein Touring have a near OEM (Boge ) feel on my 1988 750. The only downside was the strut rod is not threaded as far down as the Boge and I had to put a flat washer under the brass washer just below the strut lock nut to be able to torque her down and stop any rattles. Not any big deal but if you go that route remember this post. I bought my struts from PROAM Auto in Texas for $65.00 each
Bear is offline
post #4 of 8 (permalink) Old 07-14-2004, 01:23 AM
ex owner/admin
Furious's Avatar
Quoted: 1 Post(s)
i went with the bilstein sports and H&Rsports, absolutely no complaints.
Furious is offline
post #5 of 8 (permalink) Old 07-14-2004, 08:49 AM
thekid's Avatar
theres no problem with installing them on an E36.
thekid is offline
post #6 of 8 (permalink) Old 07-14-2004, 12:42 PM Thread Starter
what if I got an adjustable shock. Would the softest setting be clost to stock? Then I could set it to firm when I needed the handeling.
wulley1 is offline
post #7 of 8 (permalink) Old 07-14-2004, 01:19 PM
You bottom the car out on stock sport suspension? Maybe you blew a damper. used
If you want a stock ride feel get the Boge Automatic Gas or Bilstein Touring paired with either H&R OE Sport Stage 1 or Bav Auto sport springs. An adjustable KONI damper on the softest setting would still be much stiffer than stock. You don't really have many options. Most people lower the car and upgrade dampers because they want better looks along with better handling. I'd say, look into the H&R OE Sports, they are only 1" lower than stock and they are very soft springs.
Bry
<a href='
target='_blank'>- VIEW MY MODS AND PICS</a>
<a href='
target='_blank'>- PARTS FOR SALE</a>
&lt;img src=&quot;
Autotechnica is offline
post #8 of 8 (permalink) Old 07-14-2004, 06:23 PM Thread Starter
thanks for the input, it's been really helpful. I wouldn't have gotten what I want with out it.
I do bottom the car out alot, and have to go over obsticles carefully. Speed bumps, I always have to crawl over. I park in a parking garage, and you have to go to the top floor to get to the exit. When I get to the top of the ramp I have to crawl over the lip or it will bottom out.
wulley1 is offline
Rear Shock / Spring Interchange slyhog-22056 1,6,7,8 - Series and Mini Cooper 2 07-26-2005 10:25 AM
Auxiliary Input Using Blitzsafe/soundgate mattchapman Audio and Electronics 7 01-27-2005 01:15 PM
shock spring combo thing buuhh99 3-Series (E36) 12 04-01-2004 11:23 PM
