Spring Rate Opinions? Track Set Up - BMW Forum - BimmerWerkz.com
Old 05-05-2012, 10:31 AM   #1 (permalink)
bmwccr is on a distinguished road
Okay-I want some input on spring rates-I am planning on upgrading to the 4100 ASTs with Hyperco springs-am thinking of either 600lb front/700 rear or 650f/750r-Turner recommends 700f/800r for the Group N set up but Bimmerworld said between 500f/600f and 600r/700r respectively
Background-I have a 96 328is that is predominantly a track car-Its driven on the street less than 500 miles per year-trailered to events-I drive and instruct at car club events on road courses all over the NW
I run the TMS non M swaybars, treehouse control arm bushings and delrin/urethane mounts everywhere else. I have had H&R coilovers on the car since I started tracking the car. I run -3 in the front for camber and -1.5 in rear usually-car is corner weighted
I have a custom roll bar that welded into a box at the top of the rear shock mounts-all Turner reinforcement plates have been welded in-subframe, camber arms, etc
Car is 2800lbs-stock aero for now but I will be adding a better front end soon too.-over time I will continue to lighten the car as well-
I have been happy with the H&R set up over the years but the car is slow to transition-has slightly more roll than I want-Overall, handling characterstics are fairly nuetral at most tracks and I don't want to lose that balance
I want the ride height to be around 12.5/13-from center of hub to fender
Any experience out there with ASTs and various spring rates? I know most of us have to compromise between handling and comfort but in my case I can certainly go on the stiff side-however, I am looking for a balanced car that can still be driven on the street occassionally
bmwccr is offline   Reply With Quote
2012 North Central Track Dates - MVP Track Time Feffman North Central 1 06-16-2012 07:22 AM
2011 MVP Track Time North Central Track Dates Feffman North Central 3 04-08-2011 06:08 AM
2010 MVP Track Time Track Days Schedule Feffman Bimmer Talk/Motorsports Talk 4 07-18-2010 07:59 PM
2010 MVP Track Time North Central/Midwest Track Dates Feffman North Central 1 01-07-2010 02:45 PM
Spring Rate question for e36 328i Tochenzo 3-Series (E36) 5 08-08-2006 09:45 PM
