Speedo Problem - BMW Forum - BimmerWerkz.com
Old 01-29-2009, 03:09 AM   #1 (permalink)
lrobertwood is on a distinguished road
Speedo Problem
Hi there wonder if anyone can help my speedo only seems to work now and again???? plus sometimes when im driving all warning lights come on for a few seconds then go off is it a big problem
lrobertwood is offline   Reply With Quote
Old 01-29-2009, 04:26 AM   #2 (permalink)
Help from over the pond
marti5's Avatar
Car: E38 1997 728i Individual
I would say you have a loose connection behind your cluster.
Old 01-29-2009, 04:54 AM   #3 (permalink)
is it much of a job getting to the cluster ???
Old 01-29-2009, 05:31 AM   #4 (permalink)
marti5's Avatar
Look at the dash cowl that shades the top of the guage cluster from below. You will see two torx screws at approx. 10 o'clock and 2 o'clock. These take a T15 torx bit. It is a tight fit and the easiest way to access them is with a torx bit socket and a small wratchet. These are the only thing holding the guage cluster in.
If you havent got a torx set you might aswell get one as all BM's use these, I have the sockets and screwdriver sets. Cheap sets are fine.
If your from the UK , screwfix do them.
Old 01-29-2009, 06:31 AM   #5 (permalink)
ta very much for your advice yeah from uk cumbria
Old 01-29-2009, 11:00 AM   #6 (permalink)
marti5's Avatar
Well your ok then as screwfix do all the weird sockets etc for these.
Old 01-29-2009, 06:07 PM   #7 (permalink)
MMSTech's Avatar
MMSTech is on a distinguished road
You probably need a new cluster.
MMSTech is offline   Reply With Quote
Old 01-22-2010, 12:11 AM   #8 (permalink)
wayne003 is on a distinguished road
Talking speedo prob
check that it is earthed well
I had a prob with the speedo & fuel gauge not working, the earth from the fuel pump sender & speed sender in diff on same earth check that it is earthed properly
wayne003 is offline   Reply With Quote
Old 01-29-2010, 03:11 AM   #9 (permalink)
bimmergrl99 is on a distinguished road
having the same issue however i have been told possible ground wiring problems???? any ideas? replaced gauge cluster and i have power just no correct readings....help?
bimmergrl99 is offline   Reply With Quote
Problem With Speedo On 1991 E34 535i ben_t 5-Series (E12,E28, E34, E39, E60) 0 12-29-2004 01:51 AM
Speedo Problem Foley 3-Series (E21, E30) 1 12-06-2004 08:15 AM
160 top out speedo is it a problem buuhh99 3-Series (E36) 39 08-18-2004 12:30 PM
Speedo Problem pogiboy9 3-Series (E21, E30) 1 03-30-2004 07:21 PM
Yes another Speedo problem Aussie_323i 3-Series (E21, E30) 1 09-24-2003 06:25 PM
