Speed sensor malfunction - BMW Forum - BimmerWerkz.com
Old 05-28-2008, 04:44 PM   #1 (permalink)
Car: 1999 328i
brent1777 is on a distinguished road
Send a message via Skype™ to brent1777
I have a 99 328i and it started doing weird things. First the A/C fuse kept blowing, then the left front indicator, ABS and traction control lights come on, and the speedometer stopped working. Code P0500 comes out to be a "speed sensor malfunction" which apparently could be the root as it would cause a short. I have ordered one ($41) but now need to know where to find it to replace it! Thanks.
brent1777 is offline   Reply With Quote
Old 05-29-2008, 12:02 AM   #2 (permalink)
darkhorse737's Avatar
Car: 88 super ETA, 95 525i
VEHICLE SPEED SENSOR = it's the rear right wheel speed sensor. It provides the input to ABS & ECM for vehicle speed limiting, and idle speed regulation.
*could be just a disconnected line or dirty sensor surface ;-)
Old 06-17-2008, 02:25 PM   #3 (permalink)
Car: 1999 328i
Sadly, that was not the sensor that the AutoZone analysis showed needed replacing. It was certainly more accessible if it had been that one. The one that they gave me is located above the transmission. However, I finally got it to someone with a more expensive computer that identified the problem to be with the ABS computer. Once that was replaced ($1,200 - sigh) the fault codes went away and the speed sensor ($41) was returned...
Old 06-17-2008, 02:40 PM   #4 (permalink)
Wow. Sorry to hear all that!
Old 06-17-2008, 02:50 PM   #5 (permalink)
*sigh.... (i will sigh with you on this one)
2004 X5 speed sensor JABSHIRE 1,6,7,8 - Series and Mini Cooper 0 08-25-2004 09:37 PM
1993 BMW 325IS vehicle speed sensor fryebzky 3-Series (E36) 4 06-17-2004 11:32 PM
RPM and Speed Sensor Wires saidebug M-Series (M1, M3, M5, M6) 0 06-13-2004 12:28 PM
Where is Speed Sensor ? p3rsian 3-Series (E36) 2 02-25-2004 03:30 PM
Speed sensor and speedometer, is there a link? :D M5power 5-Series (E12,E28, E34, E39, E60) 3 02-03-2004 08:18 PM
