sounds like a belt is lose or something - BMW Forum - BimmerWerkz.com
Old 08-26-2004, 10:16 PM   #1 (permalink)
tico481's Avatar
tico481 is an unknown quantity at this point
Send a message via AIM to tico481 Send a message via MSN to tico481
When i start going from a stop, the car squeels like a belt is lose, kinda like some cars sound when the AC is on but it stops after like a second. It's not creating any problems with the car, its just annoying me and I want to fix it. Anybody else have this problem? I'm almost positive its a worn out belt, but would I be able to change it myself??
<u>1995 BMW 325is</u>
- //M3 Spoiler
- 15% Tinted Windows
- Front License Plate Delete
If I say something stupid, it's probably cause I'm ripped
tico481 is offline   Reply With Quote
Old 08-27-2004, 07:20 AM   #2 (permalink)
BLACKBMW's Avatar
BLACKBMW is an unknown quantity at this point
Its your fan belt...it either needs replacing through wear and tear or needs tightening slightly...you can take up slack by loosening off the bolt which holds in your widget (alternator?) and by using some force and a large screwdriver you can pry it back and forth until the belt is tight again...dont over tighten..you need about 1 cm of play in it...this will eliminate the squeal...if it doesn't then the "teeth" on the fan belt are worn and the whole belt needs replacing
hope this helps
J...
<img src='http://img.photobucket.com/albums/v629/BLACKBMW1/alssig.jpg' border='0' alt='user posted image' />
Thought for the day: &quot;d'uh&quot;
BLACKBMW is offline   Reply With Quote
timing belt change and mechanics in miami träumer 3-Series (E21, E30) 6 10-03-2005 03:44 PM
1990 E30 V belt picture/diagram/info sought snpower 3-Series (E21, E30) 5 09-10-2005 07:07 PM
Broken Timing Belt?? jaymz 3-Series (E21, E30) 12 10-17-2004 08:22 PM
Passenger Side Seat Belt Install YoungExec728 3-Series (E36) 1 10-13-2004 12:34 AM
Replacing Alternator/Fan Belt chardotcom 3-Series (E36) 1 12-05-2003 08:18 AM
