| In in NY now, so I can't do anything else with it, but I can tell you that you have an oil leak. there's a spot in my garage.
Also, I never adjusted the Low pass xover, just the boost and the gain. turning up the x over will make the subs play a greater range of frequencies, so you'll probably need to then turn the gain and boost down.
2000 MR-S Roadster= Current</span></span> |
