Simple Power Steering Question - BMW Forum - BimmerWerkz.com
post #1 of 3 (permalink) Old 07-28-2006, 03:15 PM Thread Starter
Paige is on a distinguished road
Noticed some leaking from the power steering resevoir. Did what I always do first ... came here. Maybe need to replace those hoses. But... I noticed that someone here said to check the gasket on the plastic fill cap. Mine has no gasket there. It's just plastic to plastic. Maybe someone lost it when they checked the PS fluid at some time? Or? Is there supposed to be a rubber gasket or O ring there? Thanks!
Paige is offline
post #2 of 3 (permalink) Old 07-29-2006, 07:20 PM
Been here a while.
97alpineM3's Avatar
97alpineM3 is a name known to all 97alpineM3 is a name known to all 97alpineM3 is a name known to all 97alpineM3 is a name known to all 97alpineM3 is a name known to all 97alpineM3 is a name known to all
There should no gasket.... it will boil over with PS fluid... you should fill with ATF fluid... fyi, if you did not know...
The hoses have hydralic fittings... which suck IMO... easier to replace with normal screw fittings...
Good Luck,
Les
1997 E36 M3 1990 E30 325i
97alpineM3 is offline
post #3 of 3 (permalink) Old 08-01-2006, 03:19 PM
ex owner/admin
Furious's Avatar
Quoted: 1 Post(s)
chances are after you have checked what Les has said, i would really check those factory clamps that secure the lines on the bottom of the PS resevoir. its very common for those to fail, just use newer screw fittings instead of those cheap pressure fittings. 90% of the time thats the leaking problem
Furious is offline
Power Steering Lubing the Turbo? iMagnusX Forced Induction 20 05-20-2006 02:18 AM
Power steering resevoir location warrentt 3-Series (E46, E90) 5 12-05-2005 03:21 PM
Power steering WRX 3-Series (E46, E90) 3 10-30-2005 09:50 AM
Anyone Good With Fluid Leaks? Could It Delmarco 3-Series (E36) 14 11-08-2004 10:51 PM
