Should I put in M3 bushings? - BMW Forum - BimmerWerkz.com
Old 07-03-2004, 05:32 PM   #1 (permalink)
Defector
El Presidente's Avatar
Wondering if I should got for the m3 bushings, since my originals are shot.
What performance enhancement will i feel with the stock suspension?
Old 07-03-2004, 05:37 PM   #2 (permalink)
WOT in Reverse
jllphan's Avatar
They should fit fine, they do on my car. You will notice a little firmer ride if anything, and is just a better part. My mechanic recomends them for anyone wanting to replace with better than standard oem replacements.
Old 07-03-2004, 05:39 PM   #3 (permalink)
Defector
any idea on the cost difference?
Old 07-03-2004, 06:47 PM   #4 (permalink)
Which bushings? Control arm, rear trailing arm, shock mounts, tranny, diff etc..
I didn't really notice any difference when I swapped to the '95 style M3 offset CA bushings. It wasn't any stiffer but they last a hell of a lot longer. Obviously I had more turn-in because of the offset.
I felt a slight increase in stiffness when I swapped to the M3 rear trailing arm bushings. However, my previous bushings were pretty worn out so I can't really compare the two. They also last longer as they have a metal casing which compresses the bushing when installed.
If you're more performenace oriented, I'd opt for the Urethane bushings. Unless you can find super good deals on M3 parts or find them used, I think it'll be more worth it to go with the Urethane bushings.
Anyways, swapping in M3 parts can only do good things for your car Some parts are identical to regular E36's though, so becareful what you swap. Some dealer part numbers have different part numbers for M3's and regular 3 series, even though they are the exact same part. They actually charge more for the M3 parts in some cases. eg. M3 rear trailing arm bushings have different part numbers than the 96+ E36 bushings, even though they are the same.
Bry
Old 07-03-2004, 07:12 PM   #5 (permalink)
WOT in Reverse
jllphan's Avatar
Bry
Are you sure about that? My tech told me they were not the same and installed the ///M versions based on longer life and a denser composite. He could have just made that up to charge me more, but I have used him for a number of years and never had the feeling he was jacking me around.
At any rate, Autotechnica said it, ///M parts are usually nothing but good for your car. It may just take some getting aclimated to (right Auto, stiff clutch , but it takes a little getting used to :wink ).
Old 07-03-2004, 07:22 PM   #6 (permalink)
Threadkiller
bitcore's Avatar
I had my LCA bushings replaced and it's a lot better now than it was. I say you get them, if not those, then go ueathane
Old 07-03-2004, 07:26 PM   #7 (permalink)
Defector
well the dealer that is doing the work will only install OE parts, otherwise I would go for urethanes. I'll call and see what the rpice difference is. Hopefully I'll be able to get a loaner, since today that got $750 some dollars, and are about to get $2000 more.
Old 07-03-2004, 07:32 PM   #8 (permalink)
mikester328's Avatar
mikester328 is an unknown quantity at this point
Send a message via AIM to mikester328
$2000 ? Your car is about 4 to 5 times as much as far as how much your car is worth... we really have fun with these machines but we do pay for them... Good luck Pres with your installation and all.
Mike
mikester328 is offline   Reply With Quote
Old 07-03-2004, 07:38 PM   #9 (permalink)
Threadkiller
bitcore's Avatar
we need the forumla one jacks in our car... press a button and the car jacks it self up a foot in like, 1 second.
Old 07-03-2004, 09:01 PM   #10 (permalink)
The '95 and earlier RTAB were actually discontinued due to their faulty design. After 1996 they actually used the M3 bushings in all '96+ E36's. Yet another part that BMW should have but did not recall.
Anyways, I've compared the E36 '96+ bushings and the M3 bushings, they are indentical. If I'm wrong, feel free to crap all over my comparison. :wink
Bry
Old 07-03-2004, 09:51 PM   #11 (permalink)
Defector
I say 2k. Its really a collection of one time stuff due to milage so its not that bad.
cooling system check (make sure everything is fine after todays flush)
brake system diagnostic (not sure why this is there, need to ask)
o2
bushings
guibo
alignment
tires
The total minus the o2 is $1756.04.
Plus im not paying for it this time.
Old 07-03-2004, 10:44 PM   #12 (permalink)
Kevin325i's Avatar
Screw urethane, delrin is the way to go people.
Anyone know where I can get a set of urethane bushings for my 325i. Any thoughts at all? I need the sway bar ones and LCAs the most. If you know of an offset urethane bushing that'd be even better.
Kevin
Kevin (President TBEA)
Old 07-03-2004, 10:45 PM   #13 (permalink)
Defector
bmpd carries a wide selection of bushings.
Old 07-04-2004, 01:17 AM   #14 (permalink)
WOT in Reverse
jllphan's Avatar
I REALLY want those....
Old 07-04-2004, 02:19 AM   #15 (permalink)
uber e36's Avatar
uber e36 is an unknown quantity at this point
Send a message via MSN to uber e36
el presidente... i'm hammered getting home from the club at 3:30am... pm me about this and i'll get you the cost difference... i think it's worth it... the stock bushings are filled with holes to give a smoother ride, as opposed to the m3 which are solid and give a tighter response....
Click signature for pictures:
Need some Real Estate Advice? www.gracehomes.com
uber e36 is offline   Reply With Quote
Anybody Installed M3 Control Arm Bushings? abemcclellan 3-Series (E36) 6 03-10-2005 02:53 PM
Got M3 Bushings Today -pimpin328is- 3-Series (E36) 10 10-15-2004 06:07 PM
# of bushings on a 318i? fushuman 3-Series (E36) 6 07-12-2004 06:12 PM
Control Arms, Bushings, or both? clmautz 3-Series (E46, E90) 3 07-08-2004 11:28 AM
Differential Bushings Groucho 3-Series (E46, E90) 0 02-27-2004 10:00 PM
