shocks spring coilover kit - BMW Forum - BimmerWerkz.com
Old 02-27-2004, 08:17 AM   #1 (permalink)
Live Fast. Drive Faster.
buuhh99's Avatar
buuhh99 has a reputation beyond reputebuuhh99 has a reputation beyond reputebuuhh99 has a reputation beyond reputebuuhh99 has a reputation beyond reputebuuhh99 has a reputation beyond reputebuuhh99 has a reputation beyond reputebuuhh99 has a reputation beyond reputebuuhh99 has a reputation beyond reputebuuhh99 has a reputation beyond reputebuuhh99 has a reputation beyond reputebuuhh99 has a reputation beyond repute
Send a message via AIM to buuhh99
is it hard to install those shocks with springs around them they look easy i have installed shocks before but not springs so i know how to do that but what about those
buuhh99 is offline   Reply With Quote
Old 02-27-2004, 08:58 AM   #2 (permalink)
bimmerfan620's Avatar
bimmerfan620 is an unknown quantity at this point
Send a message via AIM to bimmerfan620 Send a message via Yahoo to bimmerfan620
you must be refering to the Mcpherson setup. If you buy the kit and they come pre-assembled, i.e. springs already mounted on the struts, then your job is a whole lot easier. Removing the unit out of each corner of the car is not hard at all, but always requires a new alignment for the vehicle after. anything you install springs on these kind of cars, you need a set of spring compressors that work on the outside of the spring and the job is about a 2 out of 4 wrenches on a mechanical skills level....
FOUNDER of the BMW-Forums Michigan Club
<span style='color:green'><a href='http://www.cardomain.com/memberpage/458339' target='_blank'> Car Domain UNFINISHED </a> </span>
<img src='http://www.bmw-forums.com/forum/uploads/post-4-1078289877.jpg' border='0' alt='user posted image' />
bimmerfan620 is offline   Reply With Quote
Old 02-27-2004, 06:06 PM   #3 (permalink)
buuhh99's Avatar
good wont be to hard then
Old 02-28-2004, 01:33 AM   #4 (permalink)
Defector
El Presidente's Avatar
so we still havent seen any pics of this car of yours.....
Old 02-28-2004, 08:41 AM   #5 (permalink)
buuhh99's Avatar
don't have a car of my own only 15 but friend and dad got one i just do stuff on thiers but i won the bid on ebay for one just didn't meet the reserve hopefully i will get it my dad is goin to call him today i think a 95 325i would be a good car for a 15 year don't you think
Old 02-28-2004, 11:13 AM   #6 (permalink)
Threadkiller
bitcore's Avatar
Manual or auto? If it's auto, DO NOT do any tricks in it... I F&$#ed up my transmission REAL BADLY... 3rd gear is slipping and i'm currently driving really easy to nurse it as long as I can.. Thats the worst situation to be in... you have a nice sportscar and you can't drive it like your suppose to because you messed it up.
Old 02-28-2004, 12:30 PM   #7 (permalink)
Defector
At 15 how do you plan to pay for all these mods you want?
Old 02-28-2004, 01:57 PM   #8 (permalink)
buuhh99's Avatar
i have a preety good paying job i work with my friend the one with the bmw he is 19 has we have a boat cleaning buisness pays 50 bucks an hour becasue it is only me and him in it get like 200 bucks a boat and only takes like an hour and 30 minutes to do one and i have bben savin for the past 2 years and mowin lawns so it saves up pretty quick over time
Old 02-28-2004, 01:58 PM   #9 (permalink)
buuhh99's Avatar
o it is a manual so don't have to worry about that stuff
Old 02-29-2004, 10:55 AM   #10 (permalink)
Doogle325's Avatar
Doogle325 is an unknown quantity at this point
Send a message via AIM to Doogle325
Hey BITcore.......I was wondering what you ment by tricks????? I have a 92 325i auto and I drive it hard all the time......no probs with the tranny..Knock on wood!!!!! Lemme know what these tricks are so I can avoid these maneuvers....thanx
Doogle325 is offline   Reply With Quote
Old 02-29-2004, 12:36 PM   #11 (permalink)
Threadkiller
bitcore's Avatar
Well, drifting with ebrake while in gear, power slides, anything that makes a sudden change in motion to the drive train. Such as hitting the ebrake while in gear... I suggest you slam the stick forward into neutral and give it at least a couple seconds for it to fully disengage before you hit the ebrake...
Don’t drop it from neutral to any gear, wither it's accidental or not. That’ll really $#&#$ up the transmission, differential, and anything else in-between, much more so in an auto than dropping a clutch in a manual. Many manual clutches have springs to absorb some of the shock of such engagement, (excluding performance clutches and maybe even BMW's, they might not have said springs but it’s still not as bad as doing so in an auto)
Try not to power slide into a curb... or anything for that matter. Your wheels, axles, differential, and tires don't like that.
Get a LSD if you’re going to drift, otherwise doing so might tear up an open diff from all of that torque going to one wheel, plus it will be a lot easier to drift. Best if the car doesn’t shift gears while mid-drift, the transmission wont appreciate it when it shifts, the wheels suddenly gain traction and stop spinning mid-shift, and it fully engages into 2nd or 3rd with power being applied at relatively high RPM’s. Guess what you just "dropped the clutch" again. Be sure your able to force the gear shifts with a manual button or whatever.
Avoid jumps or getting the wheels airborne more than 6 inches, you slam your suspension among other things. Take a look at my sig, that car was royally messed up after they filmed it.
I guess DRIVING it on like a course is fine, although still stressful its much better than hitting the ebrake around corners and all the crazy & stupid crap I do.
I think I reduced the value of my car by about 10,000 after I have driven it for like 7 months...
I want new: engine, transmission, differential, headlights, and shocks. Thats a lot of work and probably less expensive just to by a new friggin M3 or somthing.
F/S: E36 M3 1995 Conforti Euro Intake Kit Locu Aftermarket Parts 11 11-29-2005 11:57 AM
New shocks needed theironm0nk 3-Series (E36) 7 11-14-2005 09:03 AM
Is It Bad To Just Changing The Spring? E46speedking 3-Series (E46, E90) 1 10-13-2004 07:08 AM
sport shocks vs. touring? 87bimmer 3-Series (E21, E30) 7 07-08-2004 09:34 PM
bilstein shocks for e39 h2oskidad 5-Series (E12,E28, E34, E39, E60) 0 08-06-2003 09:07 PM
