shaking... - BMW Forum - BimmerWerkz.com
Old 05-15-2006, 12:25 AM   #1 (permalink)
aotiko2 is on a distinguished road
shaking...
I have shaking in my wheel consantly. The faster I go the worst it gets. I just had my tires balanced and aligned. My front and rear bushings were just replaced and the rest of the car was checked out at BMW for anything else that would need to be replaced. I was told one wheel was bent. I moved it to the back and nothing improved. I can't think of what else would cause shaking if the whole car was checked. Would rotating my tires do anything because of irregular wear?
1995
325i
Automatic
aotiko2 is offline   Reply With Quote
Old 05-15-2006, 05:55 AM   #2 (permalink)
Been here a while.
97alpineM3's Avatar
Car: Blah
Sounds like brakes... I'd be willing to bet your rear brakes are warped.
Good Luck,
Les
1997 E36 M3 1990 E30 325i
Old 05-15-2006, 11:21 AM   #3 (permalink)
that would make the car shake even if I'm not pressing the brakes?
Old 05-15-2006, 11:31 AM   #4 (permalink)
Been here a while.
97alpineM3's Avatar
Car: Blah
You'd be amazed... yes it would...
Les
Old 05-15-2006, 11:33 AM   #5 (permalink)
Wow, this will be great. Another 600 bucks?
Old 05-15-2006, 04:57 PM   #6 (permalink)
98three28i's Avatar
98three28i is an unknown quantity at this point
it could also be just the wheel...how bad is it?
I had two of my 17" M Contour replicas by At Italia straitened by a company in Newton MA www.rimandwheelworks.com for about $120/wheel and it fixed any vibrations i had...except over 115 mph...its noticeable again
<img src='http://www.bimmerwerkz.com/forum/uploads/post-19085-1125500838.jpg' border='0' alt='user posted image' />
98 328i ECIS CAI / Tint 35% / 17&quot; Gun-Metal Gray M Countour style wheels with Polished chrome lip and 235/40/17 Toyo Proxe T1-R's / Silverstar bulbs - head and fog
System - Calrion ProAudio HU / MB Quart RA 1000 Sub amp, RA 4200 4 ch amp / MB Quart PCE 213 5.25&quot; seperates front / JL Audio VR 6.5&quot; seperates in rear / Stinger SPDH5 Pro-Hybrid 5 farad Capacitor / Alpine Type X 12&quot; DVC Sub in a slot ported box
98three28i is offline   Reply With Quote
Old 05-15-2006, 09:25 PM   #7 (permalink)
aotiko2,
What kind of tires do you have? Find a local tire shop that uses a Hunter 9700 Road Force balancer. It has an external wheel that rides on the tire tread to measure actual roundness of the whole assembly. Many, many of the lower priced low profile tires are completely out of round, and total junk, and nothing will fix the vibration they create. Falkens come to mind here. Its best to pay the money and go with the bigger name tire companies rather than the off-brands.
http://www.gsp9700.com/
Find a Hunter 9700 near you. Many of the new car dealers use them exclusively. Almost every BMW dealer has one.
Mike
Hamfisted is offline   Reply With Quote
Old 05-15-2006, 09:28 PM   #8 (permalink)
Sodium Chloride
saltshaker185's Avatar
Car: 95 M3
im backing with les on this one... sounds like a warped rotor i think... whens the last time youve had those changed and do you brake hard enough to heat them up pretty hot??
Old 05-15-2006, 09:38 PM   #9 (permalink)
hahaha i have falkens! they didn't do that at the beginning though. I only had one bent rim and moved it to the back and there was ZERO improvement. THere should have been at least some from doing that.
Old 05-15-2006, 09:48 PM   #10 (permalink)
There ya go...
aotiko2 ,
Put those things on a Hunter 9700, I bet you don't have one truly round tire in the set. Get about any other brand and you'll be surprised. A tire shop with a 9700 can actually rotate the tire on the rim and try to make the whole assembly a little more round, but it's only a bandaid approach with Falkens. If you can afford some Michelins that would be great. But any other brand but Falkens.
Mike
Old 05-16-2006, 08:46 PM   #11 (permalink)
kylek325i is on a distinguished road
Send a message via AIM to kylek325i
are you still on the 17's? I had 18's on my car when i got it and i had bad vibrations. Put on the stock 15's and wouldn't you know, MUCH better (PO didnt know much about cars, let alone BMWs). check also that there is nothing obviously wrong with the steering/ suspension/ undercarriage. And if you have all original brakes, they might indeed need replacing. good luck-
kylek325i is offline   Reply With Quote
1990 525i e34 vibration / shaking at around 80km/h (50mph) stonedewok 5-Series (E12,E28, E34, E39, E60) 2 11-17-2005 03:12 AM
:help Abs Shaking While Low Speed Over Pot Holes vexlak 5-Series (E12,E28, E34, E39, E60) 0 04-03-2005 11:38 PM
2002 E39 530da Shaking When Idle larscph 5-Series (E12,E28, E34, E39, E60) 11 11-12-2004 01:08 AM
car starting shaking 99bimmer 3-Series (E46, E90) 7 06-12-2004 01:58 PM
shaking problem socalguy 3-Series (E36) 16 06-03-2004 08:27 PM
