Service Indicator - BMW Forum - BimmerWerkz.com
Old 01-07-2005, 11:28 PM   #1 (permalink)
epheterson's Avatar
epheterson is an unknown quantity at this point
Send a message via AIM to epheterson Send a message via MSN to epheterson
My rainbow line (the dots from green to red) is on yellow, and saying that I need oil service, I got an oil change and it's still saying I need oil service. Any clue what might be wrong?
<img src='http://bmwpics.pheterson.com/bimsig.jpg' border='0' alt='user posted image' />
epheterson is offline   Reply With Quote
Old 01-07-2005, 11:31 PM   #2 (permalink)
jamesw is an unknown quantity at this point
Need to reset the indicator correctly.
James
jamesw is offline   Reply With Quote
Old 01-08-2005, 10:58 AM   #3 (permalink)
Threadkiller
bitcore's Avatar
the lights have NOTHING to do with if you have actually changed the oil or not. The lights are "dumb" meaning, they do a calculation of miles vs. some other factor like how hard you drive or how long the engine has been over 5K or something neat.
If you change the oil regularly and make sure your undercarrage is in working and safe order, you can safely ignore those lights. They are there to remind 45 year old women (and men) who know nothing about cars, nor care about all the engine components, that "HEY, YOU *NEED* TO CHANGE THE OIL NOW!!!"
There is a method to reset the service and oil service lights with a very expensive tool called a "paper clip", most everybody has one laying around their desk or kitchen junk drawr or something. If not, call up a neigbor and ask if you can have a paperclip from them.
Short pins 7 and 19 with the paperclip on the data port for like 10 second while you turn the ignition on.
Pin 19 is ground and is the same as the car's body like this dude did.
http://www.unofficialbmw.com/e36/electrica...ice_lights.html
This dude actually wasted money on making a much more elaborite tool than he needed to.
Old 01-08-2005, 03:26 PM   #4 (permalink)
Henri is an unknown quantity at this point
By the way, if you try this DIY, it's VERY easy and without any electrical knowledge, I made my tool for a big... 5$ and it work nice
Henri is offline   Reply With Quote
Old 01-08-2005, 03:35 PM   #5 (permalink)
Threadkiller
bitcore's Avatar
once again, the paperclip does the exact same thing electrically as a tool does. No need for wires or anything.
Find the ground pin on the pinout and the service reset pin. Short those two.
Old 01-08-2005, 03:52 PM   #6 (permalink)
http://www.bmw-forums.com/forum/topic11734.html
This works fine.
Old 01-08-2005, 10:28 PM   #7 (permalink)
Been here a while.
97alpineM3's Avatar
Car: Blah
Also.. Peake Research has a reset tool... which also reads "Check Engine" ECU codes for you... www.turnermotorsports.com sells them for a good price.
Good Luck,
Les
1997 E36 M3 1990 E30 325i
2001 E39 Brake Service Due Indicator. djathome 5-Series (E12,E28, E34, E39, E60) 2 06-06-2005 06:39 PM
Inspection I iantosca 3-Series (E36) 5 09-18-2004 12:18 AM
Oil Service Indicator Gargoyle69 3-Series (E46, E90) 14 06-16-2004 11:51 AM
