I don't know wxactly what the procedure is, but you should be able to run the self-diagnostics on your vehicle. All pre-96 vehicles are OBDI, which allows for the pedal diagnostics. Furthermore, I think OBDII didn't get implemented in all vehicles poutside of the US until a few years after that, so certainly yours is OBDI.
kilocharlie- from the off pos. turn your key 2 clicks (which i believe is the on pos. right before you start the car) and you must press the gas pedal all of the way to the floor 5x before the abs light goes out. timing is key when doing this, so keep trying and you will get it. then your abs light will start to flash and that sequence is the fault code. you can find out the code descriptions in your bentley. hope this helps.
__________________ BMWcrazy
___________
-Joshua
BMWCCA member#407674
Oh cry me a river you OBDII people. You guys can build your own system diagnostic systems. Go to your local book store and look for a book called Geek my Ride. Somewhere in the later chapters it tells you about buildign a computer/harness system to read out your own codes.
many thanks to all that helped, i'ma try it tonight.
can't believe you have to time the blinks of the dash light and depending if its a 1 or 2 sec blink that determines if its a 1 or 2 in the 4 digit code.
