Scary oil change - BMW Forum - BimmerWerkz.com
Old 03-20-2009, 11:43 PM   #1 (permalink)
jmo69's Avatar
Car: 1998 328is 2003 325xi
jmo69 is on a distinguished road
Scary oil change
Got off work early today and decided to attempt some minor rust repair. After I had the bare metal treated I decided to check the oil. Pulled the dipstick and thought I found the dreaded 'pudding'. Looked under the oil cap and found nothing and the coolant was clean at the proper level. I'm leaning towards short trips in cold weather as the culprit, the car has never even gotten close to overheating ( the usual cause for blown head gaskets). When I put the drain plug back in it didn't go in easy and I thought I had cross threaded it . I think someone did at one time but didn't ruin all the threads, I was able to restart it and got it to seal . Next time I'll try to chase the threads or find one of those self-tapping plugs, used one on my wife's old Concord and it worked quite well. At least my new Peake Research tool worked and reset my oil sevice lights. Sorry I got so long winded.
Cosmos schwartz metalic Sparco strut brace factory X-brace 55w 6000k HID w/LED angel eyes smoked Lamin-X blacked out sidemarkers,tails and brakelights. DDM smoked corners and pedals. 35% tint all around, Prosport water temp and oil pressure gauges, Home Depot lip, M3 rear diffuser ASC-T delete.
jmo69 is offline   Reply With Quote
Old 03-20-2009, 11:50 PM   #2 (permalink)
AFAIK, the oil level may appear to be low when checked cold. Hope that helps.
Old 03-20-2009, 11:59 PM   #3 (permalink)
jmo69's Avatar
It wasn't the level I was concerned about, the back of the car was on jackstands, it was the little bit of foam on the dipstick that had me worried.
Old 03-21-2009, 03:00 AM   #4 (permalink)
Pandemonium Director
nukeduster's Avatar
Car: turbo 325is, 325es, Audi a4 turbo
foam = overfilled oil level = more dangerous for an engine than too little oil.
Old 03-21-2009, 11:23 AM   #5 (permalink)
jmo69's Avatar
Oil level was good, it was a moisture issue, I only have a 1 1/2mi. drive to work each day.
Old 03-21-2009, 05:46 PM   #6 (permalink)
jmo69's Avatar
Update
Finally got everything done, ie rust repair, snow tire removal, went to start it and nothing. Only some of the lights on the cluster lit up and not even a click from the starter. Battery voltage was 8.25v. Trunk was closed but not latched and the keys were not in the ignition. I'm hoping the trunk was the cause, the only thing different was that I've got a tape in the deck but with the key out it should be off.
Old 03-21-2009, 07:46 PM   #7 (permalink)
jmo69's Avatar
edit: Definitely the trunk light, trunk has to be latched for the light to go off.
OIL LEAK....scary need help storiesfalling13 3-Series (E36) 2 07-30-2008 10:36 AM
Oil Change/oil Inspection Light Reset 2002 525i mssoetaert 5-Series (E12,E28, E34, E39, E60) 5 08-08-2005 05:42 PM
Oil Change, What Oil Is Recommended ? Q_BMW 3-Series (E36) 11 09-23-2004 04:36 PM
reseting oil bar after oil change on e36 LIMaxin 3-Series (E36) 6 08-26-2004 11:42 PM
Oil Change using an Oil Extractor bearing01 3-Series (E46, E90) 6 04-12-2004 08:38 PM
