s50 flywheel and clutch in 325 transmission? - BMW Forum - BimmerWerkz.com
Old 01-25-2006, 09:15 PM   #1 (permalink)
catalyst. is an unknown quantity at this point
Send a message via AIM to catalyst.
I need to know it this will work ASAP..
im planning on putting an s50 flywheel and a sach's m3 clutch/to bearing/pressure plate in my trans..
will it work? will i need any other parts?
thanks.
catalyst. is offline   Reply With Quote
Old 01-25-2006, 09:40 PM   #2 (permalink)
anything else i should replace while im in there?
backup light switch?
im upgrading the slave to the m3 one..
Old 01-25-2006, 09:57 PM   #3 (permalink)
General Chaos
SpeedInfusion's Avatar
Car: ///M3,Corolla
should work...
Old 01-26-2006, 06:30 PM   #4 (permalink)
Originally Posted by SpeedInfusion
should work...
should or will..
i know for a fact furious has experience with this..
Old 01-27-2006, 02:16 AM   #5 (permalink)
ex owner/admin
Furious's Avatar
s50 yes, they are both getrag trannys, if its a bit pricey than dont bother, but if your getting it for a steal than go for it... ill have to look into the flywheels though, i thought they were relitively the same thing
reason i say is because there really isnt that much of a significant difference. if you want, save up and buy a LTW flywheel and clutch assembly, yes its more money, but you will actually have some form of performance gain.
Old 01-27-2006, 08:52 AM   #6 (permalink)
I dont have enough for a LTW unfortunatly, the reason im switching to M3 is because its only about 50 bucks more, and is a significantly bigger clutch..
Also, i need a new flywheel as mine has 142k on it, and the only used ones (with reasonably mileage) i can find are M3 because so many people upgrade to LTW flywheels.
thanks for the input
Old 01-27-2006, 11:56 AM   #7 (permalink)
93 325i's Avatar
This WILL definitely work.. flywheel and all
Complete mod list and pics:
My 1993 325i
Old 01-27-2006, 05:35 PM   #8 (permalink)
thanks.
Damn your car is looking good these days, nice cardomain.
Old 01-28-2006, 11:01 AM   #9 (permalink)
93 325i's Avatar
thanks man, it may be up for sale soon.. I am M shopping..
My 1993 325i
Anyone With 93 325is Running M3 Clutch & Flywheel? BMDub325is 3-Series (E36) 4 01-17-2005 02:13 PM
M3 Clutch And Flywheel theruss1an1 3-Series (E36) 8 11-09-2004 09:03 PM
Problems with M3 clutch after install Autotechnica 3-Series (E36) 20 07-03-2004 07:01 PM
E36 M3 UUC Flywheel Wrong Clutch Becherert 3-Series (E36) 1 03-09-2004 01:39 PM
