Running Rich - BMW Forum - BimmerWerkz.com
Old 08-05-2005, 03:31 PM   #1 (permalink)
Byron320i is an unknown quantity at this point
Send a message via MSN to Byron320i
I have the idle bounce problem talked about in the FAQ section but i have cleaned the ICV and replaced both the o2 and temperature sensors with no luck.
The gas analyser says its running rich but i've run out of ideas to what it could be.
Any help would be appreciated
Byron320i is offline   Reply With Quote
Old 08-05-2005, 04:47 PM   #2 (permalink)
nobrakese36's Avatar
nobrakese36 is on a distinguished road
Send a message via Yahoo to nobrakese36
[snapback]367654[/snapback]
do you do your own maintanance? ive heard of a lot of shops saying they replace things but they really dont, check your spark plugs my dads friend had a wild a idle problem it was that the spark plugs were never changed.
nobrakese36 is offline   Reply With Quote
Old 08-05-2005, 04:57 PM   #3 (permalink)
Originally posted by nobrakese36+Aug 5 2005, 03:47 PM--><div class='quotetop'>QUOTE(nobrakese36 @ Aug 5 2005, 03:47 PM)</div><div class='quotemain'><!--QuoteBegin-Byron320i@Aug 5 2005, 12:31 PM
Any help would be appreciated*
[snapback]367672[/snapback]
[/b][/quote]
Spark plugs are brand new mate, thanks for the advice tho
Old 08-05-2005, 05:58 PM   #4 (permalink)
Car: 1993 325i
victorgallas is an unknown quantity at this point
Send a message via ICQ to victorgallas Send a message via AIM to victorgallas Send a message via MSN to victorgallas
Originally posted by Byron320i+Aug 5 2005, 04:57 PM--><div class='quotetop'>QUOTE(Byron320i @ Aug 5 2005, 04:57 PM)</div><div class='quotemain'>
[snapback]367678[/snapback]
[/b][/quote]
I have the same issue with my engine.
Ive done all you have done so far, and have even replaced the MAF sensor and did not do much os a change.
What i did last month and seemed to help was to use a fuel injector cleaner. Apperantly when the injectors on this car gets dirty, or some deposits, they tend to let more fuel go in.. Look on google for a gold system fuel injector system, is something called like that. it comes on a gold looking can and you put it on the gas, is a very concentrated fuel injector cleaner, therefore i recomend doing this before changing your oil, since this tends to dilute your engines oil.
Anyway i used the chevron fuel injector cleaner and i did some help, but as soon as my next oil change comes i will try the gold can.
let me know if you do this and tell me how it goes. thanks]
Victor
You are a BMW driver when you become part of the &quot;Ultimate Driving Machine&quot;
Fraude an Fahren
BMW &gt; Bayerische Motorenwerke
Auf Viedersehen der herr
www.clemsonfsae.com
victorgallas is offline   Reply With Quote
Old 08-06-2005, 08:25 AM   #5 (permalink)
Thanks, my Mechanic thinks you could be right and has even suggested taking the head off for a full clean, but i think i'll try your suggestion first.
I let you know what happens
Old 08-06-2005, 05:43 PM   #6 (permalink)
Car: 1993 325i
[snapback]367772[/snapback]
Cool, Let me know what it does, i know that there is places that you can send your injectors and they clean them for you. Also you could clean them yourself in case you have an ultrasound machine,,, anyway i dont thjink you need to remove the head, as normally i doubt the valves get carbonazed with such mileage,
keep us posted.
Fraude an Fahren
www.clemsonfsae.com
Running Rich... Charleston Chu 3-Series (E21, E30) 4 10-10-2005 04:51 PM
735i, 1985, Gas Running Very Rich George L. Marchin 1,6,7,8 - Series and Mini Cooper 0 07-07-2005 10:49 AM
Running Rich eskiasu 3-Series (E36) 3 03-22-2005 01:27 PM
E36 Rough Idle - May Be Running Rich Then Lean... Seros 3-Series (E36) 2 02-21-2005 05:27 PM
