Rumbling/rattling Under My Feet - BMW Forum - BimmerWerkz.com
Old 01-11-2005, 08:26 PM   #1 (permalink)
325is1994 is an unknown quantity at this point
i jus noticed this rumbling/rattling goin on under my feet, when im idling it feels like its going along with the idle, feels as if it might go away when i take off
when i was outside the car it seemed like it was coming from a little bit in front my rear driver side wheel
<a href='http://img136.exs.cx/my.php?loc=img136&image=bmwcopy3kb.gif' target='_blank'><img src='http://img136.exs.cx:81/img136/8032/bmwcopy3kb.th.gif' border='0' alt='user posted image' /></a>
mods: intake, m3 exhaust, chip, carbon fiber hood and emblems, clear corners, reverse indiglo gauges
stereo: panasonic touch screen, polk component set in q logic kick panels, kicker 5 channel amp, 12&quot; kicker square
325is1994 is offline   Reply With Quote
Old 01-11-2005, 09:44 PM   #2 (permalink)
jkh2828 is an unknown quantity at this point
check the guibo, tell tale symptoms.... pelican parts for a DIY guide aka flex disk. you can easily see if it needs replacing by visual inspection.
<img src='http://www.jbheiss.com/pics/BMW.jpg' border='0' alt='user posted image' />
jkh2828 is offline   Reply With Quote
Old 01-11-2005, 09:49 PM   #3 (permalink)
i jus replaced the guibo less than 3k miles ago
Old 01-19-2005, 05:21 PM   #4 (permalink)
Car: 1993 325i
victorgallas is an unknown quantity at this point
Send a message via ICQ to victorgallas Send a message via AIM to victorgallas Send a message via MSN to victorgallas
check to see if the exaust system is probperly held on place.
check the screw on pipe connection for tighness.
then check the rubber donuts that go between the exaust and the cars body, they are called hanger, if they crack, brake, the exaust has no place of support so it will bang on what ever it gets closer too it.
also there is a matel support brakcet between the bottom of the transmission and the exaust. it is very common for shops to take the part out when doing service and not putting it back because they think is not necessary. but hey, germans are smart, if the part is there is for a reason. to give support for the exaust and to ensure it wont move in any direction while driving..
normally when somthing on the exaust gets loose it will vibrate together with the engine, since they are connected..
check that first.
if not, let me know.
You are a BMW driver when you become part of the &quot;Ultimate Driving Machine&quot;
Fraude an Fahren
BMW &gt; Bayerische Motorenwerke
Auf Viedersehen der herr
www.clemsonfsae.com
victorgallas is offline   Reply With Quote
Wet Feet dplane 3-Series (E36) 2 09-20-2004 03:37 PM
Cold feet... Help 3-Series (E36) 8 04-21-2004 07:02 PM
