I finally got the pedal trick to work but its not flashing me any codes....it flashes "check engine" then a 1 sec steady flash "check engine" and repeates this cycle.....now according to
Mototronic Fault codes when it just flashes once for the early model mototronic that means an Air Flow sensor. But I dont think I have that version, because I tried to just put the key in position and it didnt start flashing the code. And theres no 1111 code for Mototronic 3.x, I have no Idea whats going on here, can anybody help?
Here are some specs from a VIN decoder...
Series: E36
Model: 325i
Body type: saloon
Catalog model: USA
Production date: 1991 / 10
Engine: M50
Transmission: Automatic
Steering: Left
Catalyzer: YES
it goes......Flash "Check Engine", 1 sec steady flash "check engine", and repeates cycle over and over again....sat there and watched it for like 5 minutes just kept flashing 1,1,1,1...
ghead
