Rough idle & jumping idle - BMW Forum - BimmerWerkz.com
Old 06-06-2004, 11:36 AM   #1 (permalink)
Keep it Copacetic
///M Power's Avatar
Car: 1995 BMW M3
mi friends e36 has a rough idle. when u tur it on the idl jumps to 1400 then drops to 500 almost dying then jumps again. im thinking its the MAF sensor? any ideas? cud it be spark plugs? fuel pump?
Old 06-06-2004, 12:42 PM   #2 (permalink)
mathetas is an unknown quantity at this point
Send a message via AIM to mathetas
I just got an account today... However, on other cars I've seen with those symptoms, I've suspected a vacuum leak or insurgence of air somewhere in the system. I've diagnosed such problems by spraying a little carb cleaner around the intake or breather. If the idle settles and improves a few seconds after spray, you're on your way to finding an air leak. But, like I said, I have 0 experience with BMW's. I just got mine last week. You're probably right, as sophisticated as these cars are, it is probably something electrical - that I obviously wouldn't know about.
Just a suggestion. Hope no one bites me for my post. For all I know, BMW's might not even have vacuum lines!
mathetas is offline   Reply With Quote
Old 06-06-2004, 02:15 PM   #3 (permalink)
Speedy-325is's Avatar
read the "idle problem..." thread on pg. 3 its @ 8-10 down from the top. there are quite a few good idead for troubleshooting problems like this. just take it slow when you go searching and be meticulous, if u miss something u might diagnose incorrectly. good luck..
let us know what happens.
Old 06-06-2004, 05:51 PM   #4 (permalink)
Kevin325i's Avatar
Clean the ICV valve. Info in the FAQs. Good luck
Kevin
Kevin (President TBEA)
Old 12-22-2008, 05:20 PM   #5 (permalink)
318ise36318is is on a distinguished road
Rite Heres Ur Answer Dme Relay! Get Aftermarket One 4 Pin! Problem Sovled! Trust Me!!!!!!! About A 5 Pounds! Dont Get One From Bmw It Made My Bm Rev Up To 4000 Revs And Just Stuck There
318ise36318is is offline   Reply With Quote
89 325i Rough Warm Idle And Other Odd Problem mattpark 3-Series (E21, E30) 8 03-19-2005 10:46 PM
Rough Idle After Spark Plug Change parker1000 3-Series (E36) 17 03-04-2005 01:06 AM
rough idle when ambiet temp is cool non-phixion 3-Series (E36) 0 08-13-2004 10:11 PM
very hard cold starts+ rough idle ????? jshores7 3-Series (E36) 5 03-02-2004 08:57 PM
