Rough Idle - BMW Forum - BimmerWerkz.com
Old 03-14-2005, 02:27 PM   #1 (permalink)
komodo's Avatar
komodo is an unknown quantity at this point
Hey, it started a while ago and now is getting worse. When my car is idleing (like at a redlight, or when I first start it), it sometimes starts shaking and jerking violently. When I slightly touch the gas and raise the rpms a bit, it stops and is perfectly smooth. I remember a thread a long time ago about something similar and it was their idle control valve, or something like that?
Any ideas? Thanks.
komodo is offline   Reply With Quote
Old 03-14-2005, 02:29 PM   #2 (permalink)
Gomerino's Avatar
Car: 1994 325is M-Technic
Gomerino is on a distinguished road
Send a message via AIM to Gomerino Send a message via Yahoo to Gomerino
try cleanin the ICV
Gomerino is offline   Reply With Quote
Old 03-14-2005, 05:50 PM   #3 (permalink)
What? No Autobahn?
jrhaile's Avatar
Car: 2001 M5
jrhaile jrhaile jrhaile jrhaile jrhaile jrhaile jrhaile jrhaile jrhaile jrhaile jrhaile
Send a message via ICQ to jrhaile Send a message via AIM to jrhaile Send a message via MSN to jrhaile
clean your idle control valve... or replace it...it's located under your intake manifold.
Also check vacumm lines for clogs and or holes. Check your battery because the ICV is 12v and if a weak battery is in place, an ICV can't function properly.. this actually happened to me last summer. Check o2 sensor/s. Run some injector cleaner through your car too. I do this stuff about 3-4 months now.
jrhaile is offline   Reply With Quote
Old 03-14-2005, 08:10 PM   #4 (permalink)
komodo's Avatar
Hum, how much money do you think we're talking for cleaning, or replacing the ICV?
Old 03-14-2005, 08:20 PM   #5 (permalink)
What? No Autobahn?
jrhaile's Avatar
Car: 2001 M5
to clean it you can do yourself...to replace, 100 bones for the part.. probably an hour to 2 in labor
Old 03-14-2005, 10:00 PM   #6 (permalink)
drz
master of his domain
drz's Avatar
Car: zhp
Just clean it out. Easy and cheap. Will very likely fix your problem. There are DIYs on this site, and I think they explain how to do it on the Bently manual also (you have one, right?).
Turkey Fleet Bond Holder
Rough idle & jumping idle ///M Power 3-Series (E36) 4 12-22-2008 05:20 PM
89 325i Rough Warm Idle And Other Odd Problem mattpark 3-Series (E21, E30) 8 03-19-2005 10:46 PM
Rough Idle After Spark Plug Change parker1000 3-Series (E36) 17 03-04-2005 01:06 AM
very hard cold starts+ rough idle ????? jshores7 3-Series (E36) 5 03-02-2004 08:57 PM
