Rough Idle? - BMW Forum - BimmerWerkz.com
Old 11-23-2004, 05:39 PM   #1 (permalink)
streetdreams is an unknown quantity at this point
Just bought this 92 325i and it idles rough when the car is cold and then sometimes at a stop. The seller told me it was a vacuum leak. He said to get the Idle Air Control Valve hoses (2) and that would fix the problem.
The check engine light is on as well, Im going to VatoZone shortly to see why it on.
streetdreams is offline   Reply With Quote
Old 11-23-2004, 06:21 PM   #2 (permalink)
[snapback]236227[/snapback]
These early 325 engines have a lopey or irregular idle, even when warm. I took the electrical connecor off of the Idle control valve, took all hoses off and sprayed contact cleaner in the electrical connector area and throttle body cleaner into the valve itself. I put it all back together and it works fine (still has the irregular idle). As to check engine light, at first start ,the lght is on until you step on the brake pedal, then the light should go off.
Old 11-23-2004, 06:29 PM   #3 (permalink)
Just got back from AutoZone, they said they could not test it there and that it would be hard to find a code reader for my car. Where can I get the code tested? My Dad owns a Honda shop, will his OBD1 code reader work?
Old 11-23-2004, 06:31 PM   #4 (permalink)
[snapback]236244[/snapback]
What about the light? My light stays on all the time.
Old 11-23-2004, 06:34 PM   #5 (permalink)
FruityOne's Avatar
FruityOne is an unknown quantity at this point
Send a message via AIM to FruityOne
the vacuum leaks are hard to track down...theres a billion hoses underneath the intake manifold. the other possible problem could be your idle control valve. and your idle will still be rougher than other 325's simply because the 92's had hotter cams then other M50 motors because they lacked the variable cam timing that other m50 motors came with.
93 325is - SOLD (white car in sig)
92 325i - 220rwhp/205rwtq (RIP)
02 GSXR 600 - 107rwhp/48rwtq
95 M3 - 220rwhp/205rwtq
President & Founder OF S50 Swap Club
THC the three most powerful letters in my veins...
FruityOne is offline   Reply With Quote
Old 11-23-2004, 07:01 PM   #6 (permalink)
[snapback]236249[/snapback]
Alright, I'll look into that tommorow and get back to you.
Old 11-23-2004, 07:03 PM   #7 (permalink)
Speedy-325is's Avatar
if u think its a vaccume leak, mist the suspected areas with starter/brake cleaner spray....with the enging idling.....if the rpms jump after u mist the area....thats where u look for the leak.
its a simple way to track it down, but dont over do it w/the spraying. LIGHT MISTING SPRAYS.
Mark
Old 11-23-2004, 07:16 PM   #8 (permalink)
FruityOne's Avatar
only problem with spraying is that the hoses are all under the intake manifold...
Old 11-23-2004, 07:26 PM   #9 (permalink)
its possible....just put a small hose line,, or a straw over the nozzle on the can...and use it to reach underneath.
Rough idle & jumping idle ///M Power 3-Series (E36) 4 12-22-2008 05:20 PM
89 325i Rough Warm Idle And Other Odd Problem mattpark 3-Series (E21, E30) 8 03-19-2005 10:46 PM
Rough Idle After Spark Plug Change parker1000 3-Series (E36) 17 03-04-2005 01:06 AM
very hard cold starts+ rough idle ????? jshores7 3-Series (E36) 5 03-02-2004 08:57 PM
