Rim fitting - BMW Forum - BimmerWerkz.com
Old 01-07-2004, 06:11 PM   #1 (permalink)
Pino's Avatar
Pino is an unknown quantity at this point
Thumbs down
I was looking through some old posts similar to this one......you guys said that 18inchers on a 325iS would mean that i'd have to raise it.
Is that true?
Theres this kid at my school who put 18's on his 325i and its not raised at all...i think its lowered 2inches
THANKS!
oh, and any rim sugestions would be appreciated
gotta post this -
Pino is offline   Reply With Quote
Old 01-07-2004, 06:27 PM   #2 (permalink)
Defector
El Presidente's Avatar
18s dont require raising, they require rolling.
Old 01-07-2004, 06:45 PM   #3 (permalink)
Pino's Avatar
rolling?!?!?!!? wtf is that
Old 01-07-2004, 06:58 PM   #4 (permalink)
Defector
rolling is litterally what it sounds like. The lip on the fender has to be rolled out to allow for clearance when turning the wheel.
Old 01-07-2004, 07:26 PM   #5 (permalink)
trinidon2k's Avatar
trinidon2k is an unknown quantity at this point
Send a message via AIM to trinidon2k
rolling?....never heard of that myself....how much does that cost?...would i have to change my fenders?.....i was just about to buy gunmetal 18's today but it was out of stock
trinidon2k is offline   Reply With Quote
Old 01-07-2004, 07:49 PM   #6 (permalink)
e36_m3_Turbo's Avatar
no u dont change fenders...its lik ur fender is strecthed inside of the wheel well.
No longer red.
Old 01-07-2004, 07:50 PM   #7 (permalink)
also the long time affects of rolling is rustin if not repainted well
No longer red.
Old 01-07-2004, 07:51 PM   #8 (permalink)
well not in all cases. i have seen many 325i's with 18's and the fenders were not rolled.
No longer red.
Old 01-07-2004, 08:16 PM   #9 (permalink)
Pino's Avatar
CCONNFUSSSSSEDDDD!!!!!1 ghead lol
ok, in a couple simple sentances - what would i need to do to put 18's on a 325is and how much would it cost.
Old 01-07-2004, 08:18 PM   #10 (permalink)
trinidon2k's Avatar
WORD...i want to know the same thing
Old 01-07-2004, 08:57 PM   #11 (permalink)
Defector
18s that are 7.5" will fit without rolling. 18s that are 8" will most likely rub, unless a very very very low profile tire is run. Also, rolling shouldn't require repainting to prevent rust if done correctly. To roll the fender lip, you can take it to a local body shop and they can do it, or you can DIY with a hairdryer, towel, and wooden baseball bat.
If you do it at home, you want to heat the metal with the hairdryer. it makes the metal easier to bend and reduces risk of cracking the paint. After metal is hot, roll the lip of the bat inside the lip of the fender, gently applying outward pressure. I suggest wrapping it in a towel to prevent scratches.
Old 01-08-2004, 02:23 PM   #12 (permalink)
Pino's Avatar
would u have to roll back the skirts also? since its on the opposite side and a wheel is round?
do u think u could post a pic of a car and point to the parts that need rolling? thanx
Old 01-08-2004, 09:49 PM   #13 (permalink)
bimmerbill's Avatar
bimmerbill is an unknown quantity at this point
17x8s 225/45 in front
17X9s 245/40 in the rear
thats the best way to go . . . my .02
&quot;we stared perfection in the eye, perfection blinked&quot; BMW
bimmerbill is offline   Reply With Quote
Old 01-08-2004, 11:40 PM   #14 (permalink)
Defector
the rear fenders only need to be rolled in extreme cases. 9s would most likely require it. The area that needs to be rolled out is the entire lip.
Old 01-09-2004, 10:51 PM   #15 (permalink)
Pino's Avatar
hey......would these fit on a 325iS????? I was consitering the 18x7.7 Tire Package 1 OR 2 (w/e u think)
http://www.gotwheelsandtires.com/catalog/p...products_id=363
cracked rim kman 5-Series (E12,E28, E34, E39, E60) 5 10-27-2005 09:17 PM
Rim Bolt Pattern 325e? Enthuziast 3-Series (E21, E30) 6 10-23-2005 08:35 PM
Fitting a second Headunit M3wannabe2004 Audio and Electronics 3 06-26-2004 09:58 AM
Slave Cylinder Bleeding Help BmWNoobie 3-Series (E21, E30) 5 12-13-2003 07:32 PM
fitting strut braces or strut bars ultraman90 3-Series (E46, E90) 6 11-25-2003 02:18 AM
