Revs + Idle - BMW Forum - BimmerWerkz.com
Old 12-27-2004, 06:13 AM   #1 (permalink)
mmclaren is an unknown quantity at this point
uneven idle revs bounces around for a bit, almost about to stall
then when i accelerate quickly then slow right down it almost stalls, "and yes it has stalled doing it"
1994 bmw 318i e36 m43
i have a new engine ready to be installed so if its an engine problem good cos it will be gone soon, but if its not, wat is this problem
mmclaren is offline   Reply With Quote
Old 12-27-2004, 10:10 AM   #2 (permalink)
Been here a while.
97alpineM3's Avatar
Car: Blah
Sounds like a sticky and or dirty ICV valve... Locate that sucker .. take it out.. and clean it.. then rubbing alcohol... and let it dry.. then put it back in..
Good Luck,
Les
1997 E36 M3 1990 E30 325i
Old 12-27-2004, 06:36 PM   #3 (permalink)
ICV VALVE???
Where can i locate this?? DIY or mechanic??
Old 12-27-2004, 07:20 PM   #4 (permalink)
RedlinedRU's Avatar
RedlinedRU is an unknown quantity at this point
Send a message via AIM to RedlinedRU
Idle Control Valve.....i think its near your intake manifold, but not exactly sure. definately a DIY though i would think
<span style='color:green'>
AMG can't build an NA engine that can compete with M engines, so they stick in a supercharger and say their cars are faster. BMW could simply do the same, but they don't out of principle.</span>
RedlinedRU is offline   Reply With Quote
Old 12-27-2004, 08:06 PM   #5 (permalink)
350z
Car: 03 Nissan 350z Track
im about to do it on my 325 its easier to locate on the 318, check the fact forum there is agreat write up on it
David
**BAKER POW REPORT**
Old 12-27-2004, 08:07 PM   #6 (permalink)
350z
ill take the trouble out of looking
http://www.bmw-forums.com/forum/index.php?showtopic=506
David
Old 12-28-2004, 03:04 AM   #7 (permalink)
thx
shall try that tomorrow happy that i have managed to get rid of the metalic rattling sound
Old 12-28-2004, 07:24 AM   #8 (permalink)
hardboiled2 is an unknown quantity at this point
The idle control valve probably need replacing. I replaced mine once. The flucuating idle is back but I havent replaced it again. It doesnt stall and its only a slight flucuation.
hardboiled2 is offline   Reply With Quote
525 Idle Revs Itself leetman 5-Series (E12,E28, E34, E39, E60) 10 10-22-2007 08:53 PM
Idle Problems BeelZibub 5-Series (E12,E28, E34, E39, E60) 10 07-10-2005 04:56 AM
Bad Engine Idle And Fault Not Found.. Paraklas 3-Series (E21, E30) 10 06-16-2005 09:25 PM
