Reverse Light Problem - BMW Forum - BimmerWerkz.com
Old 01-24-2005, 01:50 AM   #1 (permalink)
BeemerMan's Avatar
Car: e36 328is
BeemerMan will become famous soon enoughBeemerMan will become famous soon enough
hey guys! i was wondering if any of you know why my reverse lights intermittently work. Sometimes they light up and sometimes they don't. used any ideas?
BeemerMan is offline   Reply With Quote
Old 01-24-2005, 07:40 AM   #2 (permalink)
Car: 1993 325i
victorgallas is an unknown quantity at this point
Send a message via ICQ to victorgallas Send a message via AIM to victorgallas Send a message via MSN to victorgallas
first off, check and see if they are properly fitted to the tail light holder and that they have clean and good contacts..
then if its a manual, it is mosk likely that your reverse trasnmission swicth is about to fail, ,mine is gone, just waitng warmer weather to change.
anyway to replace, lift the car, get a new swicth and jsut uncrew the other and put the new one in. and then plug the wire to it.
if its an automatic, then the gear selector sensor is gone.
there is a electric siwch underneat the gear selector that tells the computer what is the selected gear.. and it also turns on the reverse lights.
any questions. ask.
You are a BMW driver when you become part of the "Ultimate Driving Machine"
Fraude an Fahren
BMW > Bayerische Motorenwerke
Auf Viedersehen der herr
www.clemsonfsae.com
victorgallas is offline   Reply With Quote
Old 01-24-2005, 10:22 AM   #3 (permalink)
Power Shifting
Cruzin 323is's Avatar
i had that problem.. so i changed the socket.. and it hasn't done it since!
-SOLD..
R.I.P Fast 6
Old 01-24-2005, 06:25 PM   #4 (permalink)
kestrel325is's Avatar
Car: 1995 325is 5-speed
kestrel325is is an unknown quantity at this point
My reverse lights didn't work at all. Replaced the reverse switch on the trans, everything works now. I'd check there first.
kestrel325is is offline   Reply With Quote
Old 02-16-2005, 08:51 PM   #5 (permalink)
nookatee is an unknown quantity at this point
Send a message via AIM to nookatee
any one have any pictures of where the reverse switch is on the manual transmission? Also, how much did one of those switches run you? what are they called so I can check prices online?
nookatee is offline   Reply With Quote
Old 02-17-2005, 12:29 AM   #6 (permalink)
ddunkin is an unknown quantity at this point
[snapback]293309[/snapback]
Bavarian Auto has them listed as "Back Up Light Switch - Manual transmission " for $11. I think they're easy to find on the transmission but, I had my shop replace it while I had it in. Mine has died twice in 2 years, so I don't consider it a reliable part.
ddunkin is offline   Reply With Quote
Old 02-17-2005, 01:04 AM   #7 (permalink)
theruss1an1's Avatar
Car: Needs momentum
theruss1an1 is an unknown quantity at this point
Send a message via AIM to theruss1an1
I had the same case as kestrel325is did.
theruss1an1 is offline   Reply With Quote
Old 02-27-2005, 05:17 PM   #8 (permalink)
you will need a 19mm wrench with at least a 10 degree offset in order to pull this bad boy out.
Clutch not angaging on reverse gear! 4tunesfool 3-Series (E46, E90) 7 09-17-2004 08:41 AM
Problem with signal indicator light ye12 3-Series (E21, E30) 4 09-02-2004 11:34 PM
passenger reverse tail light heeeelp p3rsian 3-Series (E36) 2 03-27-2004 02:12 PM
330CI LED Tail light conversion problem kwoktoa 3-Series (E46, E90) 2 02-05-2004 07:47 AM
