reseting oil bar after oil change on e36 - BMW Forum - BimmerWerkz.com
Old 08-26-2004, 11:57 AM   #1 (permalink)
LIMaxin is an unknown quantity at this point
I just got my oil changed and the bar is still on yellow, how do i make it go back to green?
LIMaxin is offline   Reply With Quote
Old 08-26-2004, 12:02 PM   #2 (permalink)
iantosca's Avatar
iantosca is an unknown quantity at this point
Send a message via AIM to iantosca
You can either goto the FAQ section of this site and try and figure it out there, I'm sure there are articles on how to do it, or you can buy the service light resetter from bavauto.com or numerous other companies ... it's up to you.
98' BMW 328i - Jet Black, Black Leather, Alpine CDA-9831 HU
<span style='color:red'>For Sale:</span> Sony CDX-F5000 Xplod w/ Wiring Harness, iBook G3 900 Mhz 640 MB SDRAM w/ Original Box and Software + OS X Panther + Microsoft Office
(PM on any offers, Going on E-Bay soon ...)
iantosca is offline   Reply With Quote
Old 08-26-2004, 12:21 PM   #3 (permalink)
k2c69n's Avatar
k2c69n is an unknown quantity at this point
Take it to the dealer to have them reset it. If they charge you, tell em to shove it because im sure you've given them enough money.
*If your not living on the edge your taking up too much space*
'98 328is
k2c69n is offline   Reply With Quote
Old 08-26-2004, 01:23 PM   #4 (permalink)
BMWBeauty416's Avatar
Car: '00 M-B CLK430 Cabriolet
BMWBeauty416 is a name known to allBMWBeauty416 is a name known to allBMWBeauty416 is a name known to allBMWBeauty416 is a name known to allBMWBeauty416 is a name known to allBMWBeauty416 is a name known to all
Send a message via AIM to BMWBeauty416 Send a message via MSN to BMWBeauty416 Send a message via Yahoo to BMWBeauty416
dealer resets it
~*Teg*~
BMWBeauty416 is offline   Reply With Quote
Old 08-26-2004, 01:35 PM   #5 (permalink)
gaijin1 is an unknown quantity at this point
Go HERE and HERE for detailed instructions.
I used the paper clip method. Take a large paper clip, straighten it out and bent each end into a tight "U" using about 1/4" on each end. The "U's" will let you push the clip into the proper pin sockets on the diagnostics connector and hold the clip in place while you switch the ignition on for the appropriate time period.
Depending on your year model, you'll bend the paper clip into a large looping "U" so that you can "jump" the correct pin sockets on the diagnostocs connector.
On my '93 325i it took a few tries to get the service lights to reset to green. I discovered that I had to count the seconds that I left the ignition switch at step 2 carefully. If I left the jumper in and the ignition on too long, the lights didn't reset.
HTH
If you have problems let me know.
Fred
gaijin1 is offline   Reply With Quote
Old 08-26-2004, 11:34 PM   #6 (permalink)
zeidakiss's Avatar
zeidakiss is an unknown quantity at this point
the dealer usually servises the whole car and reblaces things like air filter, bulbs, spark plugs brakes etc. for 800bucks cnd
zeidakiss is offline   Reply With Quote
Old 08-26-2004, 11:42 PM   #7 (permalink)
Threadkiller
bitcore's Avatar
I'll show you how to do it with a paperclip tomorrow afternoon when I get home. Everyone else uses a reset tool or makes this crazy contraption that's compltetely unnessicary....
EDIT: Oh NM, didn't know that thread had pictures of how I did it now :P
