Replacing vanos seals ? - BMW Forum - BimmerWerkz.com
Old 08-16-2009, 08:14 PM   #1 (permalink)
PrInG's Avatar
Car: 95 Dakar Yellow M3, 00 1.8T VW GTI
PrInG has a spectacular aura aboutPrInG has a spectacular aura about
Send a message via AIM to PrInG
As I understand it the vanos is activated by oil pressue.. Apparently there are seals that keep the pressure from leaking out.. I've been told by a friend that owns and E46 323 that replacing your vanos seals makes a world of difference. and your car seems to have new life. He claims he bought a kit for 60 bucks and he said his power was better throughout the rpm range. Do you guys buy this ... and if its truely the case with E46 could it be true for the E36s as well even though my car isn't dual vanos.. I'm hoping that this is true so that my car can have a little more perk =) who knows what im talking about thanks.
TO HONOR: Get Honor Stay Honor if You Can't Come in Her Come Honor.
"its not banana yellow but its not golden its just that perfect creamy german goodness"
- Bow
PrInG is offline   Reply With Quote
Old 08-16-2009, 10:26 PM   #2 (permalink)
Mr. Clean
BimmerE39's Avatar
Yes, I rebuilt my Vanos no more than three weeks ago and it does make a real difference. The loss is over such a long time that you never notice but I can say right away you can tell a difference. It generally takes about 500 miles of easy driving to break the new seals in properly. After that you can really tell a difference. I definitely recommend it. However, if you don't want to rebuild your Vanos yourself you can always order a rebuild one from Dr. Vanos for $300 which includes a $150 core deposit.
Old 08-16-2009, 10:48 PM   #3 (permalink)
darkhorse737's Avatar
Car: 88 super ETA, 95 525i
Cool
I wouldn't say changing the seals is what makes the difference.
It's rather the alteration of the oil pressure in the VANOS valve so that the 6 degree spread is "reMapped" so to speak. ;-)
Since the VANOS actuator is controlled by DME, the same effect can be achieved by re-mapping DME/PCM/ECU :-)
Old 08-17-2009, 10:43 PM   #4 (permalink)
PrInG's Avatar
how difficult is it to replace the vanos and where is it located.. I'd like to do this sometime.. my car only had 87 k .. but I'd like to do it .. you think its gona bad by now
- Bow
Old 08-17-2009, 10:56 PM   #5 (permalink)
Mitchell labor estimate calls for 3.5 hrs.
I think it is much less than that.
Old 08-18-2009, 12:52 AM   #6 (permalink)
Mr. Clean
BimmerE39's Avatar
The VANOS is located at the front of the engine. You will need to remove your valve cover to have access to the Vanos unit.
Here's an entire write up on the process. Click here
Old 08-19-2009, 12:44 AM   #7 (permalink)
PrInG's Avatar
why exactly is it that you have to lock the cams and place and do that stuff. Doesn't that seem a little much. cant you just take the valve cover off slip the vanos unit out and go to town ? someone wanna explain ?
and how much of a dif. does it really make. Is it worth pulling year hair out over... The guy Ibought the car off of told me he once was hitting 2nd gear hard and spun out.. Rarely ever no matter how hard im banging gear does it break any traction at all when I'm slamming 2nd. could have somethingto do with the suspension .but .. should an M3 be able to break traction banging second gear..
- Bow
Old 08-19-2009, 01:22 AM   #8 (permalink)
Mr. Clean
BimmerE39's Avatar
Replacing the seals does make a difference, but we're not talking so much more power that you spin tires through second. If your engine is sounding like a diesel, then it's probably time to change the seals. However, if you're engine sounds normal I wouldn't worry about it...
Locking the timing is to be safe that removing the Vanos unit doesn't inadvertently shift the timing. It's just a safety precaution.
Old 08-19-2009, 05:34 PM   #9 (permalink)
PrInG's Avatar
I wouldn't say my car is running like a diesel. however every now and again it wasn't to staul. and idle funny.. Not like it did when my ICV was bad . It doesn't surge like it did when my ICV was bad.. and then it goes away after I rev the engine or drive a little ways. I've always thought the car was a little bit sluggish from 0 to 3500. I just had always assumed it was supposed to be that way for all M3s. but I can't help but wonder.. if its supposed tobe a little snappier. also I read that your supposed to get 10% mile per galon increase ... and Ive never gotten over 25 Mpg and thats babying it all highway miles.. and from what I understand they are supposed to get up to 27 or 28 mpg on the highway.. Just hoping this if I fix this it willtake care of some problems.
- Bow
Old 08-19-2009, 07:01 PM   #10 (permalink)
drz
master of his domain
drz's Avatar
Car: zhp
Don't get lazy on the cam lock. You don't want to mess up your timing.
Turkey Fleet Bond Holder
Old 08-19-2009, 08:43 PM   #11 (permalink)
PrInG's Avatar
but you have to buy special tools for that lol.... for the crank lock could you just put a punch or something in there ?
- Bow
Old 08-20-2009, 07:14 PM   #12 (permalink)
mtorque6 is on a distinguished road
very good thread guys helping me out too thnx n good question pring
mtorque6 is offline   Reply With Quote
Old 08-20-2009, 09:13 PM   #13 (permalink)
318kid is on a distinguished road
Send a message via AIM to 318kid
borrow the tool from autozone
idk if theyd have timing blocks, if they are standard for all cars they might but they should have the fan removing tool, we rented one for my old auto teachers silverado...
*IF ITS FAST AND CHEAP, ITS NOT RELIABLE*
*IF ITS CHEAP AND RELIABLE, ITS NOT FAST*
*IF ITS FAST AND RELIABLE, ITS NOT CHEAP*
318kid is offline   Reply With Quote
Old 08-21-2009, 12:11 AM   #14 (permalink)
Mr. Clean
BimmerE39's Avatar
When I did it, I did not lock the timing (which after the fact I probably should have done) but I didn't have a problem without having it locked. I think it's just an extra safety precaution and not entirely sure if it's necessary.
Old 08-22-2009, 11:10 PM   #15 (permalink)
PrInG's Avatar
hmm I think this will probably be a winter project.. along with decent sounding exhaust and some Ebay headers .. haha heard the ebay headers actually arent that bad ... I'd love to do a lightweight flywheel but dont' have the money right now and I think after the exhaust and headers might go with a chip. Ive been saving up money to either buy a motorcycle or a truck that I can start a new project on.. I'd like a truck that I can slam and look nice and also keep miles offthe M while I start to add performance to it .. thats the plan .at least
- Bow
Replacing Vanos soon.. SpeedInfusion M-Series (M1, M3, M5, M6) 10 09-22-2008 01:04 PM
E34 vanos into Non Vanos car beelzebubs FAQ's and DIY's 1 06-02-2008 03:30 PM
Replacing Hydraulic Lifters For Vanos??? E36 318i 1994 hyper_cool 3-Series (E36) 4 08-29-2007 10:20 PM
windshield seals Teh Prof 3-Series (E36) 11 03-22-2006 10:16 PM
Window Seals 007ben 3-Series (E36) 10 02-27-2004 06:59 PM
