Replacing 1998 328i Fog Light - BMW Forum - BimmerWerkz.com
Old 05-11-2005, 08:28 AM   #1 (permalink)
wags is an unknown quantity at this point
need to replace fog light~~~how do i remove old one and replace
wags is offline   Reply With Quote
Old 05-11-2005, 09:03 AM   #2 (permalink)
Rich328's Avatar
Rich328 is an unknown quantity at this point
Send a message via MSN to Rich328
There is a hole to the right hand / left hand side of the fog light - in the air vern next to it. which you should ''carefully'' put a screw driver in to and gently prize the fog light out of its mounting, - be very careful as i have broken the plastic lug which holds the fog light in place - and you then have to replace the whole unit.
hope this helps - but its been a while since i've done this.
Rich328 is offline   Reply With Quote
Old 05-12-2005, 10:43 AM   #3 (permalink)
[snapback]343257[/snapback]
Old 05-12-2005, 10:44 AM   #4 (permalink)
thanks
Bob
Old 05-13-2005, 10:59 AM   #5 (permalink)
phathaway is an unknown quantity at this point
I just did this for the first time last night. When you insert the screwdriver into the hole dont pry on the light, use a flathead with the edge vertical and press pretty much straight back. You will hit a lever that should release with only slight pressure. Finding the lever is the hardest part, if you jack the car up, and take a few of the underbody panels off (a 30 second job) will will have a better view, but this is not neccessary.
phathaway is offline   Reply With Quote
Check Control '96 328i, Light & Circuit.. gfowler 3-Series (E36) 2 12-03-2004 01:37 PM
Abs Light On '96 328i gfowler 3-Series (E36) 2 11-09-2004 09:59 PM
328i 1998 - help and advice please lc1998 3-Series (E36) 1 09-09-2004 03:46 PM
