replacemnt of thermostat - BMW Forum - BimmerWerkz.com
Old 06-10-2004, 04:28 PM   #1 (permalink)
fasin8me is an unknown quantity at this point
hi,
Does anyone have step by step instructins for replacing 1997 328i thermostat?
Thanks
fasin8me is offline   Reply With Quote
Old 06-10-2004, 04:43 PM   #2 (permalink)
Speedy-325is's Avatar
pull off the housing (3 bolts in front of engine. its black or silver and is a kinked pipe with a bubble in the middle.)
housing can be pulled out between fan blades( with a bit of work, but dont go overboard)
remove thermo (replace ALL gaskets)
put in new one w/gasket (get a low temp one, maybe 70deg/80deg.)
put housing/gasket back on
dont 4 get the 3 bolts...
enjoy!
Mark
WAIT: i forgot 2 tell u to drain the coolant/ flush it/refil it/ and get the air out of the hoses. check the FAQ's for that if ur not sure.
Transmission cooler Thermostat? Laker 3-Series (E36) 5 02-27-2009 01:36 PM
Thermostat Housing Removal E34 M20 Engine 520i tstolber 5-Series (E12,E28, E34, E39, E60) 2 05-23-2005 04:11 PM
Thermostat JamaC 3-Series (E36) 1 02-19-2005 05:11 PM
Thermostat Installed Upside Down, Maybe? YoungExec728 3-Series (E36) 2 12-09-2004 03:15 PM
Thermostat Gasket/o-ring? Brian325i 3-Series (E36) 5 10-02-2004 02:30 PM
