replaced alternator but still flickers - BMW Forum - BimmerWerkz.com
Old 01-10-2006, 12:13 AM   #1 (permalink)
wango is an unknown quantity at this point
hey guys
I figured out my car has developed unstable voltage flow.
So I replaced oem alternator with 80 amp bosch remanufactured one from pelicanparts. After replacement, I had no more flickering or blinking problem. But after 1 month, it came back
So I got another remanufactured bosch alternator from pelicanparts.
well it seemed it's gone. However, came back after 2 weeks again.
I kinda tortured pelicanparts representatives and I got another one recently. It's been 2 weeks and int/ext lights flicker again and CEL comes on/off intermittently.
I replaced belts, pulleys as well as alternator.
I'm so much frustrated. Any idea would be appreciated.
wango is offline   Reply With Quote
Old 01-10-2006, 04:12 AM   #2 (permalink)
ex owner/admin
Furious's Avatar
have to ask the obvious ones , but is your battery new? or newer? , do you have soundsystem in the car? could there be a problem or have you looked into checking the voltage regulator?
Old 01-10-2006, 02:41 PM   #3 (permalink)
thnx furious
I got, of course, new battery. A sound system by previous owner has been removed when I bought her. But there are some wires left hooked up in the dash through under the center console box.
when it comes to the voltage regulator, I thought it's located in the bosch alternator. And I happened to replace alternators 3 times, so I think voltage regulators are rebuilt too.
I narrowed some possibilities but I can't still find out
Old 01-11-2006, 12:05 PM   #4 (permalink)
92_325i is an unknown quantity at this point
sounds like the battery to me. i would go get it checked out. new doesnt always mean good. the battery good have been sitting on the shelf for a while and drained some power or just defective in the first place. also, if the battery isnt fully charged when you installed the alternators, you would be doing damage to the alternator because you're forcing it to work harder right away to get the battery charged and it often times ends up frying the alternator. take your car to a parts store and ask to have the battery tested and then the alternator. both can be done while they are still in the car and it's usually free.
<a href='http://www.cardomain.com/id/jordan92bmw325i' target='_blank'>My 1992 325I</a>
<a href='http://www.cardomain.com/memberpage/461648' target='_blank'>My 1989 Nissan 240sx</a>
<a href='http://www.cardomain.com/member_pages/view_page.pl?page_id=724529&cat=10&val=1&page=1' target='_blank'>My girls' 1998 Camaro</a>
92_325i is offline   Reply With Quote
Old 01-13-2006, 08:13 PM   #5 (permalink)
kennyl5123 is an unknown quantity at this point
i got the same problem like you. i changed two alternator and one new battery, but the voltage still unstable. When i turned on the head light, the car almost stall at idle. Do you have a 318is ? what year you have?
Kenny
kennyl5123 is offline   Reply With Quote
Old 01-13-2006, 08:58 PM   #6 (permalink)
Gator is an unknown quantity at this point
IF the lights still flicker after changing the alternator and voltage regulator, the moist likely cause is the wiring. First look at the ground wire from the battery. Disconnect the wire both at the battery and where it connects to the frame and clean the connections. If the problem still persists and there is any hint of corrosion on the ground wire replace it. If the problem still persists, do the same for the positive wire. If you still have the problem, replace both the positive and negative wires from the battery if you haven't done so already in the previous steps. Sometimes these wires develop internal corrosion that is not evident from the outside. Most likely this will solve the problem, but if it doesn't the parts are cheap and it needs to be done to eliminate them as a possibility before continuing with other trouble shooting.
Gator is offline   Reply With Quote
Old 01-17-2006, 11:51 PM   #7 (permalink)
thnx for ur advices folks.
it's 94 325is, battery is new like 3 months old.
let me check wires from battery. let me keep posting thnx again.
Ooo Bugga Replaced Dashboard mmclaren 3-Series (E36) 4 12-11-2005 08:21 AM
Head uniit flickers bmwengineer Audio and Electronics 9 10-19-2005 10:19 PM
540i Cats Replaced...more Repair Work To Come mrogers 5-Series (E12,E28, E34, E39, E60) 4 06-07-2005 06:53 AM
Should I Replaced All Fuses With 15a uclabruins1996 3-Series (E36) 3 12-05-2004 10:48 PM
X5: 0-60 in 4.0 tcpgv 1,6,7,8 - Series and Mini Cooper 6 03-30-2004 02:51 AM
