replace fuses if not broken in two? - BMW Forum - BimmerWerkz.com
Old 09-01-2004, 11:11 PM   #1 (permalink)
/Banned
okczy21 is an unknown quantity at this point
should i go ahead and just change the fuses dealing with temp, fuel, rpm, and speedo even though the fuses are not broke in two
okczy21 is offline   Reply With Quote
Old 09-01-2004, 11:57 PM   #2 (permalink)
Power Shifting
Cruzin 323is's Avatar
it can't hurt!!
-SOLD..
R.I.P Fast 6
Old 09-02-2004, 12:04 AM   #3 (permalink)
LivinFast67's Avatar
LivinFast67 is an unknown quantity at this point
Send a message via AIM to LivinFast67
y would you, like a pre-emptive strike?
<img src='http://n00106.myspace.com/00106/13/45/106195431_l.jpg' border='0' alt='user posted image' />
Breyton Inspiration 17&quot;x8.5&quot;, dde plus, euro elispoids, clear front markers/rear light's, k&amp;n ram cold air intake, Clarion Deck, 8&quot; sub tube
Member:3 pedal club
Member: 10+ years club
Member: Ran from a cop and got away club
LivinFast67 is offline   Reply With Quote
Old 09-02-2004, 12:21 AM   #4 (permalink)
/Banned
i really dont know why but ive read people changing their fuses and their speedometer would work again as if thats the problem
Old 09-02-2004, 12:48 AM   #5 (permalink)
skawful's Avatar
skawful is an unknown quantity at this point
Send a message via AIM to skawful
is it wierd not having the speedo work?
i could do the rpms (just couldnt do any fancy shifting)
<img src='http://img259.imageshack.us/my.php?image=sig8hw.jpg' border='0' alt='user posted image' />
skawful is offline   Reply With Quote
Old 09-02-2004, 01:31 AM   #6 (permalink)
/Banned
it will work if i tap the plastic but i dont wanna do that forever thats kinda ghetto
Old 09-02-2004, 02:35 AM   #7 (permalink)
2.link's Avatar
2.link is an unknown quantity at this point
Send a message via AIM to 2.link
You can take apart your gauges pretty easy and check to see if the needle is just stuck. I know when I installed my new face plates I got some epoxy down where the tach needle goes and everyonce in a while it will stick when i start up the car, I just give the dash a little hit from my wrist and it pops right up. You will need a torx screwdriver to remove the screws, there are two of them at the top of your gauge panel. Then reach over to where your light switch is and under that there is a screw; remove that screw and pull out that switch and fan(comes out as one piece) and unplug the light switch and fog light switch if you have it. Reach your hand back in that hole over toward your gauges, find the back of them and push on them, wiggle and move 'em around and they will come loose, pull them as far out as you can straight, and reach back and unplug those wires, there is a latch mechanism on them that has to be unlatched. After getting the wires unplugged work it around to get the panel out from behind the steering wheel(you do not have to remove the wheel, it comes out, it may take some time but it will come out.
After getting them out turn the gauges on their front and look at the back there are 5 or 6 screws, also torx, to be removed, after they are takin out, you have to cut a sticker about some warning about takin the gauges apart blah blah blah(like a matress tag lol) anyway once you get them apart you should be able to touch the needles and stuff. Taking the speedo needle off isnt too bad because you dont have to mark where it was before. To remove it, it takes a bit of pressure, I used two small flat head screw drivers under the needle where it slide onto the electric motor. by taking the screw driver like this (T is the needle :P) --T-- /T\ it will pop off after a bit. Look around in there and see if there is something blocking the needle, or maybe the motor is fried, i unno. Put the needle back on just line it up with the little pointer piece at 0 or w/e then reverse the breakdown and install everything back.
<img src='http://www.european-forums.com/forums/uploads/post-1-1107198379.jpg' border='0' alt='user posted image' />
Formally known as Asio.
2.link is offline   Reply With Quote
Old 09-02-2004, 05:23 AM   #8 (permalink)
Been here a while.
97alpineM3's Avatar
Car: Blah
Father always use to say... why fix something that isnt broke.. it doesnt make sence.... If they look crappy.. change them.. if they still work.. leave them.
Les
1997 E36 M3 1990 E30 325i
Old 09-02-2004, 08:21 AM   #9 (permalink)
BMWBeauty416's Avatar
Car: '00 M-B CLK430 Cabriolet
BMWBeauty416 is a name known to allBMWBeauty416 is a name known to allBMWBeauty416 is a name known to allBMWBeauty416 is a name known to allBMWBeauty416 is a name known to allBMWBeauty416 is a name known to all
Send a message via AIM to BMWBeauty416 Send a message via MSN to BMWBeauty416 Send a message via Yahoo to BMWBeauty416
my radio in my eclipse is a fine example of how a fuse can LOOK like it's just fine and perfect and not be! changing fuses or at least checking them can never hurt
~*Teg*~
BMWBeauty416 is offline   Reply With Quote
Old 09-02-2004, 10:27 AM   #10 (permalink)
nycbmw325is is an unknown quantity at this point
I agree with all the posters that said replacement of fuses can't hurt... but checking them for continuity is super easy and quick and can save you some money on replacment fuses. however, since you say that smacking the custer makes it work... it is highly unlikely that a fuse is bad since the fuse is not anywhere near the cluster. But answer my earlier post .... did everything work before you changed the faces?
nycbmw325is is offline   Reply With Quote
Old 09-02-2004, 11:22 AM   #11 (permalink)
/Banned
yeah they worked fine before i changed them, it really seems to me like the needles are getting stuck, and also my odometer is so dim you can hardly see it
Broken Foot Rest! Aloyouis 3-Series (E46, E90) 2 03-21-2005 07:41 PM
Should I Replaced All Fuses With 15a uclabruins1996 3-Series (E36) 3 12-05-2004 10:48 PM
Maitenence Checklist- The Full Monty mmzcee 3-Series (E36) 12 12-05-2004 05:43 AM
Dichedguy Billb Please Help On Replace Thermostat mnguyen11111 5-Series (E12,E28, E34, E39, E60) 2 11-03-2004 03:27 PM
Broken glass in vents Kiwi Russ 3-Series (E36) 4 07-12-2004 12:08 PM
