Removing Rear Side Windows? - BMW Forum - BimmerWerkz.com
Old 10-20-2004, 03:20 PM   #1 (permalink)
kyle_baker's Avatar
kyle_baker is an unknown quantity at this point
Send a message via AIM to kyle_baker Send a message via MSN to kyle_baker Send a message via Yahoo to kyle_baker Send a message via Skype™ to kyle_baker
Hw does the hing thing on the rear side windows work and how can i get it to let the window come out? Anyone know? please help asap. thanx in advanced.
kyle_baker is offline   Reply With Quote
Old 10-20-2004, 10:31 PM   #2 (permalink)
kyle_baker's Avatar
[snapback]214988[/snapback]
anyone know how they come loose?
Old 10-20-2004, 10:43 PM   #3 (permalink)
llzoom_zoomll is an unknown quantity at this point
Send a message via AIM to llzoom_zoomll
are you talkin bout on a 2-dr or 4 dr?
You think gas is expensive? CHECK THIS OUT:
Lipton Ice Tea 16 oz $1.19 ...........$9.52 per gallon
Ocean Spray 16 oz $1.25 .......... $10.00 per gallon
Gatorade 20 oz $1.59 ..... $10.17 per gallon
Diet Snapple 16 oz $1.29 .......... $10.32 per gallon
Evian water9 oz $1.49..........$21.19 per gallon?
Brake Fluid 12 oz $3.15 ........... $33.60 per gallon
Pepto Bismol 4 oz $3.85 ........ $123.20 per gallon
Vick's Nyquil 6 oz $8.35 .... $178.13 per gallon
llzoom_zoomll is offline   Reply With Quote
Old 10-21-2004, 02:24 PM   #4 (permalink)
kyle_baker's Avatar
[snapback]215236[/snapback]
h yes, i apologize about that. yes i am refering to the 2 dr vehicles. do you know how the rear glass can be removed? i tried to remove it, removed the manual popout opener lever thing but could not figure out how to get the hing side loose? This is for a 2 dr car. Can you help? thanx in advanced and thanx for pointing that mistake out. Thanx in advanced
Old 10-25-2004, 09:31 PM   #5 (permalink)
kyle_baker's Avatar
Originally posted by kyle_baker+Oct 21 2004, 01:24 PM--><div class='quotetop'>QUOTE(kyle_baker @ Oct 21 2004, 01:24 PM)</div><div class='quotemain'><!--QuoteBegin-llzoom_zoomll@Oct 20 2004, 09:43 PM
[snapback]215570[/snapback]
[/b][/quote]
can anyone help me?
Old 10-26-2004, 09:22 AM   #6 (permalink)
kearnyme's Avatar
kearnyme is an unknown quantity at this point
I think I can help you, several months ago someone gouged the windows on my car with a spark plug and I had to replace them. On my car I had the manual type of rear windows, power rear windows were an option, I can't tell from your post whether or not you have the power or manual type, but I think I can help you.
The first step is to:
1) Remove the trim that is covering the rear pillar, (The one that houses the light)
I think that you already did this, upon removing it you will find two screws that
secure the "latch end" of the window. Unscrew those.
2) Now you need to look at the b-pillar, or (the middle pillar that holds your seat-
belt assembly). Pop off the plastic trim that covers the black plastic seat-belt
ring that your seat-belt is fed through. (its up by your head when you sit in the
front seat). Under that you will find a half-inch nut. Uncrew that.
3) Now you will see a black plastic knob used for adjusting the height of the afore
mentioned seat-belt ring, gently squeeze that and pull untill it comes out. Be
careful with this piece, its plastic and fragile.
4) You should now be able to remove the plastic housing that covers the b-pillar
and the seat-belt fastener, next you will see a 4-inch long metal device that is
used to adjust the height of the seat-belt. There may be two more nuts that
need to be unscrewed I don't remember exactly but if their there they won't be
hard to see or get at. Unscrew those.
5) Finally slide that metal piece out and behind it you will find two screws that
hold the othe part of the window in. Unscrew those.
6) Reverse order to re-install.
____\_________/____
<u>/|OO| [llllll][llllll] |OO|\</u>
<u>| o |llllllllllllllllllllllllll| o |</u>
My sh*t is not disco. Thank You.
<img src='http://home.insightbb.com/~shahabm3/wsb/media/1063900/site1013.jpg' border='0' alt='user posted image' />
kearnyme is offline   Reply With Quote
Old 10-26-2004, 03:06 PM   #7 (permalink)
kyle_baker's Avatar
thanx amillion kearnyme. and yes i also have the manual rear side windows (for my 2dr thanx again!
Old 10-26-2004, 07:34 PM   #8 (permalink)
kearnyme's Avatar
anytime!
____\_________/____
How To Remove The Rear Side Backrest. BMWhatever 5-Series (E12,E28, E34, E39, E60) 1 11-20-2004 05:20 PM
Rear Coupe Windows ROC 3-Series (E46, E90) 8 06-16-2004 07:36 PM
List of common e46 part numbers L337E46 3-Series (E46, E90) 0 06-07-2004 09:19 AM
electrical of licence plate, rear side lights javieruz 3-Series (E21, E30) 1 03-14-2004 08:08 PM
Flasher and Rear Windows don't open bmwikonline 3-Series (E36) 4 12-17-2003 11:36 AM
