Hello!
I need some advice on removing the expansion tank of my 320i '97. There seem to be topics on this question, but i havent found a concrete answer yet. Can the expansion tank be removed without removing the radiator?
http://www.realoem.com/bmw/showparts...89&hg=17&fg=05
From the picture above, it seems that it should slide out without the need to remove the radiator, but it just wont budge. I need to change the nr. 3 gasket ring.
Can anyone give me some advice, how to remove it? Is there a trick for this, or do i just need to use some more strength?
Thanks!
