rebel locks - BMW Forum - BimmerWerkz.com
Old 12-01-2005, 10:41 PM   #1 (permalink)
BMW Kraft's Avatar
BMW Kraft is on a distinguished road
rebel locks
I want to be able to lock all my doors just by pushing down the lock in my car, but there is a problem. All the locks go down, but then seconds later they all pop back up. What the hell is going on?
If I lock the door from the outside they all lock down and stay down.
'92 318i - Bilstein Sport Tuned Suspension, Performance Tuned Chip
///BMW=-
BMW Kraft is offline   Reply With Quote
Old 12-02-2005, 12:45 AM   #2 (permalink)
cymorg's Avatar
cymorg is an unknown quantity at this point
Send a message via ICQ to cymorg Send a message via AIM to cymorg Send a message via MSN to cymorg Send a message via Yahoo to cymorg
my locks WONT push down. u just gotta use the key on the outside and then they usually unlock right after that at least once. then the second time stay locked.
what. the. heck.
cymorg is offline   Reply With Quote
Old 12-02-2005, 08:10 AM   #3 (permalink)
93 325i's Avatar
it's meant to do that..to prevent locking the keys inside the car..
Complete mod list and pics:
My 1993 325i
Old 12-02-2005, 10:37 AM   #4 (permalink)
BMW Kraft's Avatar
i'm pretty sure not, because why would all of them close in the first place. Only one would close and the rest should've stayed up if that was BMW's first intention.
///BMW=-
Old 12-02-2005, 10:54 AM   #5 (permalink)
93 325i's Avatar
from my expirence since there is no un-lock, lock button, you use the drivers (or passengers) door lock to make all door locks go up down. That is why all of them go down in the first place. I have owned 2 bimmers and both operated like this. By them popping back up (when the car is off) I assume it is a protection from locking your keys in the car by mistake.. you dont have a problem here
My 1993 325i
Old 12-02-2005, 10:58 AM   #6 (permalink)
93 325i's Avatar
cymorg- sounds like you got actuator problems. Your problem definitely is not normal nor the same as what Kraft is describing..
My 1993 325i
Old 12-02-2005, 01:34 PM   #7 (permalink)
General Chaos
SpeedInfusion's Avatar
Car: ///M3,Corolla
this is correct, its a bmw double lock system designed to prevent geniuses from locking keys in the car
Old 12-02-2005, 02:13 PM   #8 (permalink)
BMW Kraft's Avatar
glad to know my BMW is safe unfortunately I just found another problem this morning.
///BMW=-
Old 01-24-2006, 07:08 AM   #9 (permalink)
coheed is on a distinguished road
ok... try this on for size...
here is my predicament...
Say I'm getting out of my car, and my doors is open... I can't just push down the lock and have all the doors lock. They lock, but pop right back up. I've always assumed this was to prevent me from locking my keys in my car.
Therefore, I've always had to use a key to lock my door...
Now, here's where it gets interesting... This problem was intermittent before. But now is always happening.
My doors lock fine with the key in my driver's or passenger side door. All doors lock when I turn the key. BUT... when I go to unlock them from either door, they unlock, and then quickly LOCK again... So to open my doors, I have to quickly unlock, and grab the handle real quick before they lock again. If I open the door before they usually lock again, they DO not lock. (Is this possible a door-sensor type issue?). Like I said, it doesn't matter what door I use the key in, it still locks after I unlock.
Now here's the even weirder part... My key has never worked in my trunk. I don't know why. I don't think it's a frozen thing. Right now, even with the doors unlocked, I cannot open the trunk. I used to be able to, but when this unlock/lock bullshit problem started happening, my trunk stopped working. It hasn't worked since this problem started being continuous. So basically, I have no trunk access at all unless I go through my seats...
Any suggestions???????
coheed is offline   Reply With Quote
Old 01-24-2006, 07:24 AM   #10 (permalink)
ok... I just found this in a different post linked to http://auto.consumerguide.com/Auto/U...ewreliability/
"Doors: If the central locking system unlocks itself after being locked or locks itself after being unlocked, the actuators could be defective or the trunk lock may need to be adjusted. (1992-93)"
Anyone know about adjusting the trunk lock or actuators.... grrrrrrrrr....???
Old 01-31-2006, 06:26 AM   #11 (permalink)
anybody????
Old 01-31-2006, 06:46 AM   #12 (permalink)
catalyst. is an unknown quantity at this point
Send a message via AIM to catalyst.
mine does the same thing, i have no idea why.
Example: i will lock the car from the outside, the pins will go down, then up again and stay there, then to lock it i will need to turn the key again.
is that normal?
catalyst. is offline   Reply With Quote
Old 03-06-2006, 03:29 PM   #13 (permalink)
any body got anything? my trunk still won't open, and my locks are still driving me nuts...
Old 03-06-2006, 04:03 PM   #14 (permalink)
I am Teh Edumacator.
Teh Prof's Avatar
I have a similar issue, in that the key that starts the car, works the door locks, and works the glovebox lock does not turn the trunk lock at all. However, I have a separate key that looks like the master key picture in the manual that works the trunk and does not work any of the other aforementioned items. I just find it random and mildly annoying...I figured somebody had the trunk lock replaced at some point, so it's on a different key.
Lindsay fan club member.
Old 03-06-2006, 04:03 PM   #15 (permalink)
Been here a while.
97alpineM3's Avatar
Car: Blah
Locks are operated and controlled by the comfort relay... probably has a lot to do with that....
I'd have to take a look at the ETM.
Les
1997 E36 M3 1990 E30 325i
Door Locks Duge 3-Series (E36) 3 07-20-2005 07:03 PM
Door Locks Gone Haywire! ///M Power 5-Series (E12,E28, E34, E39, E60) 8 05-19-2005 12:26 PM
All My Locks Are Toasted Smooth Criminal 3-Series (E21, E30) 4 01-08-2005 10:52 AM
Did all E30's come with Pwr Locks? 2001 Yellow 3-Series (E21, E30) 1 03-28-2004 04:40 PM
1994 740i Door Locks agsiegel 1,6,7,8 - Series and Mini Cooper 3 08-06-2003 08:44 PM
