Rear tires rubbing - BMW Forum - BimmerWerkz.com
Old 03-31-2004, 10:04 PM   #1 (permalink)
mole is an unknown quantity at this point
I've been having a problem with my 95 325i with h&r sport springs where if i go over bumps.. or dips in the road.. it would make my rear tires rub..
So i replaced the rear shock mounts and shocks(bilstein) thinking it would help... but it just got worse actually.
The current tires i have on right now are 235/45 17in. Can i make some adjustments with the suspension, or will i need to buy smaller tires?
mole is offline   Reply With Quote
Old 03-31-2004, 10:25 PM   #2 (permalink)
ex owner/admin
Furious's Avatar
your starting to scare me, i have 235's on my car and ordered the same springs. i wonder how my car will react
Old 03-31-2004, 10:44 PM   #3 (permalink)
sorry. I hope you don't weigh too much.
Old 03-31-2004, 10:45 PM   #4 (permalink)
Keep it Copacetic
///M Power's Avatar
Car: 1995 BMW M3
there is definetely somethign wrong with your car. Those should not rub at all. my friend is runnign eibachs with bilets and he is tucking and doesn't rub. maybe you didnt get your suspension aligned after the springs, and maybe you didnt allign it after the shocks makign that twice that you screw with your suspension without alignment thereby making it even worse on the second suspension job.
Old 03-31-2004, 11:23 PM   #5 (permalink)
ex owner/admin
Furious's Avatar
got a little weight in the back about 120lbs in audio
Old 04-01-2004, 09:09 AM   #6 (permalink)
Doogle325's Avatar
Doogle325 is an unknown quantity at this point
Send a message via AIM to Doogle325
when you figuer out what the problem is let us all know ........I just bought Bilstein sports and was gunna order the H&R springs and try to tuck 18's under the well.......I guess ill wait on the springs and see where you went wrong.....
Doogle325 is offline   Reply With Quote
Old 04-01-2004, 12:38 PM   #7 (permalink)
Not sure if I went wrong.. they still rubbed before i put the new shocks and shock mounts in.
I just bought the car a few weeks ago, and the owner told me that it would rub if he had two fat guys sitting in the back.
Is there a way i can adjust my rear fender area above the tires? Oh.. say just hit it a few times with a bat and make some more room?
Old 04-01-2004, 11:18 PM   #8 (permalink)
Defector
El Presidente's Avatar
rolling the fenders may help.
Old 04-01-2004, 11:58 PM   #9 (permalink)
M3Daemon's Avatar
M3Daemon is an unknown quantity at this point
How much did the h&r springs drop the car?
Daemon
<img src='http://www.geocities.com/bwloka/BimmerWerksSigV1.jpg' border='0' alt='user posted image' />
M3Daemon is offline   Reply With Quote
Old 04-02-2004, 12:19 AM   #10 (permalink)
Keep it Copacetic
///M Power's Avatar
Car: 1995 BMW M3
probably 1.25 - 1.5
are you sure you bought thr right size shocks? i mean rubbing is generally noticeable on your car unless u get aftermakret shocks, but still ETF?
Old 04-02-2004, 01:19 PM   #11 (permalink)
Sorry, i don't know how much it's lowered, it was lowered when i bought the car.
Also about the size of shocks.. I'm not sure, the guy who i bought them from just gave them to me. He said he was going to replace them but didn't have the time to do it.
Old 04-14-2004, 12:47 AM   #12 (permalink)
123NotIt's Avatar
123NotIt is an unknown quantity at this point
When I bought my car it had H&R race springs which drop it 1.3" in the back. This was done on 19" rims which caused some serious rubbing problems even with my fenders rolled. I love my rims and decided instead to raise my car by swapping to H&R OE sport springs (0.5" drop in the rear). I still rubbed a little with a full load, so I found out you can use additional or larger spring pads to raise the rear. The stock size spring pad is 7.5mm I believe. I took my old worn ones out and replaced them with 2- 10mm pads on each side (stacked on top of each other - with the center cut out of one of them). Now I have no problems rubbing at all!
Here's more info if you're interested:
http://www.uucmotorwerks.com/html_techtip/...e_clearance.htm
...Just another option to adjust the height of your car.
<img src='http://sonny.ramsay.us/m3_footer.jpg' border='0' alt='user posted image' />
123NotIt is offline   Reply With Quote
19 inch rear tires eclipsevrl 3-Series (E36) 25 06-07-2006 02:40 PM
Need New Rear Tires For My E39, 540i Sport pamato 5-Series (E12,E28, E34, E39, E60) 3 02-27-2005 11:59 PM
New tires for 325i wazzubmr 3-Series (E46, E90) 2 08-10-2004 05:16 PM
Rear tires rubbing felt7916 3-Series (E36) 1 06-07-2004 02:55 PM
