Rear Tire Rubbing lowered 328i - BMW Forum - BimmerWerkz.com
Old 07-03-2006, 11:31 AM   #1 (permalink)
Car: 1997 DINAN 328i
SOLO5977 is on a distinguished road
Arrow Rear Tire Rubbing lowered 328i
I have a 97 328 i w/ Bavarian Autosport spriings and bilstein hd shocks. Rims are 17" x 8 ifront tires 225/45/17 rear 235/40/17 and the rear rubs on the outsiide edge. Does anbody have any idea what size rear tires you can run with that setiup, and if you can dial enough negative camber in to eliminate the rubbiuing?
thanks
SOLO5977 is offline   Reply With Quote
Old 07-03-2006, 11:52 AM   #2 (permalink)
RexKing86's Avatar
Car: 2006 Mitsubishi Lancer Evolution MR
RexKing86 is an unknown quantity at this point
Send a message via AIM to RexKing86
I have 235/40/R17's on my car but im not lowered, i may get that bavauto setup as well, but i fear rubbing too. the 45 series may be to much tire, maybe try 40's.
~Kingo
RexKing86 is offline   Reply With Quote
Old 07-03-2006, 12:39 PM   #3 (permalink)
had 245 / 40 and they rubbed. i think you can adjust neg camber in to eliminate the rub. I might go to 225/45 and see if it stops. If not time for HR springs the BAS's might be to soft.
Old 07-03-2006, 12:43 PM   #4 (permalink)
Sodium Chloride
saltshaker185's Avatar
Car: 95 M3
just roll the back fender if its not all that much...
Old 07-04-2006, 09:14 AM   #5 (permalink)
tomctx's Avatar
thanks
Are they OEM BMW rims or aftermarket? You should not have any problem with OEM rims on 235/40/17 tires unless you are really lowered. Do you know what the offset is? Are they 17 x 8" all around or are the rear wider?
Old 07-05-2006, 07:28 AM   #6 (permalink)
they are after market rims I think they are 38mm offset. the car is lowered already, I am trying to figure out whether I need to replace the rims or just adjust the camber
Old 07-05-2006, 05:10 PM   #7 (permalink)
ex owner/admin
Furious's Avatar
how much is the drop on those springs to be exact. to concur on what Tomx said, if the rims are the wrong offset that could be contributing to the rubbing, i had H&R sports and Bilstein sports with my old 17" rims i was running 235/40 and had absolutlely no issues with rubbing , however the rims were the correct offset and my drop was only 1.5" all around.
Old 07-06-2006, 07:52 AM   #8 (permalink)
paco1076's Avatar
Car: 1997 BMW M3
paco1076 is on a distinguished road
Send a message via AIM to paco1076
Cheapest way to fix your issue, if you aren't rubbing alot... Roll the fender edges.
1997 E36 M3 - running stocker style right now...
paco1076 is offline   Reply With Quote
Old 07-08-2006, 09:58 AM   #9 (permalink)
lots of rubbing on the upper portion of the outside fender. lowered about 1.0 in the rear and 1.5 front
Old 07-08-2006, 10:31 AM   #10 (permalink)
Keep it Copacetic
///M Power's Avatar
Car: 1995 BMW M3
If the offset is 38 just roll the fenders. Should be $25-$50 per fender. Find a local modification shop.
Old 07-10-2006, 07:23 AM   #11 (permalink)
Tochenzo's Avatar
Tochenzo is an unknown quantity at this point
Send a message via AIM to Tochenzo
i have almost the exact same wheel setup with rolled fenders and i have no issues with rubbing in the rear, except on tight turns due to soft springs hopefully i'll change that soon
Tony
National Capital Chapter BMW CCA #367673
1998 Hellrot 328i
Tochenzo is offline   Reply With Quote
Old 07-10-2006, 12:46 PM   #12 (permalink)
Live Fast. Drive Faster.
buuhh99's Avatar
buuhh99 has a reputation beyond reputebuuhh99 has a reputation beyond reputebuuhh99 has a reputation beyond reputebuuhh99 has a reputation beyond reputebuuhh99 has a reputation beyond reputebuuhh99 has a reputation beyond reputebuuhh99 has a reputation beyond reputebuuhh99 has a reputation beyond reputebuuhh99 has a reputation beyond reputebuuhh99 has a reputation beyond reputebuuhh99 has a reputation beyond repute
Send a message via AIM to buuhh99
I run a 225/40/18 and I used to rub, I rolled my fenders myself.
All you need is a baseball bat(wooden) and some touch up paint just in case you scrape some of the paint on the inside of the fender.
I used a measuring caliper and I gained about a 1 centimeter of clearance, I could roll them more but the problem is solved, and it would only net me another .2 centimeters maybe
buuhh99 is offline   Reply With Quote
Need Tire Recommendation: 328i ThomasCA 3-Series (E46, E90) 4 05-10-2005 09:16 PM
Rear Tire Groove BimmerETC 3-Series (E36) 1 02-10-2005 10:41 AM
Help needed connecting rear speaker on 328i garethdavey Audio and Electronics 0 07-28-2004 02:30 PM
Unbelievable rear tire wear cpadpl 3-Series (E46, E90) 3 06-28-2004 06:47 AM
