| Rear sag tire rub rattle I guess our rear springs are subject to cracking and breaking. We had a rattle in our left rear of my 325i convertible and had it to the garage and they replaced the rear shocks three times in two years. The left rear one kept leaking after a short period of time. The garage owner finally installed oem style because the kyb's were not holding out. Something wrong here but the last set were free along with the labor. Three weeks after the new set of shocks were installed, (and the rattle was still there) i came across a set of 17" wheels with michelins on them, real nice set. I did my homework and knew the size would be close and took the chance. Put one front wheel on and it was perfect. Put one back one on and it was also good, a little closer. I then proceeded to install the other two. With the car off the jack there was plenty of clearance on all four. Caution, if you do not roll the car, the rear suspension will not find bottom. I noticed that the tires were directional and had to jack it back up and switch two of the tires for proper rotation. That is when i found a coil and a half, at least of the rear drivers side spring broken off and sitting in the perch centered in the rest of the existing coils. This has to be what was blowing out the kyb's. The car still sits perfectly level which makes me think that the passenger side must compensate and sag with the low side. The wheel that came off the passenger side had worn right down to the steel cords along the inner edge not noticeable unless you were laying on the ground looking for it. I am hoping replaceing the rear springs with stock will give me the clearance i need, but am hoping that i don't have to find a little taller spring if someone makes one. My wheels by the way, are right out even with the lip that would have to be rolled so height is crucial here, fender roll might help. I have only posted what i found and some of my opinions, but if anyone would like to let me know if i am off track here please do!!! A little long winded, but i kept it as short as possible to explain my dillemma.
Thanx,
Dennis
