Rear End Noise - BMW Forum - BimmerWerkz.com
Old 05-24-2005, 01:29 AM   #1 (permalink)
bob325i is an unknown quantity at this point
OK, folks. Here is the problem, 1994 325i rear end make a strange sound only when going in reverse. The sound is most commonly refered to as a low pitch moan. Like an old man trying to move. Also most prevelent when turning the steering wheel to the left msking the rear go left. ANYONE HAVE AN IDEA? Thanks in advance to anyone with an idea.
bob325i is offline   Reply With Quote
Old 05-24-2005, 09:09 AM   #2 (permalink)
Been here a while.
97alpineM3's Avatar
Car: Blah
You should check your differential fluid... either that or change it... www.pelicanparts.com has a write up on how to check and replace the fluid. Rather easy really.
Les
1997 E36 M3 1990 E30 325i
Old 05-24-2005, 02:53 PM   #3 (permalink)
If it’s only when reversing I’d check out the brakes especially the parking brake
Rear suspension noise (not shock mounts) Hogfisch 3-Series (E36) 9 02-01-2011 11:04 PM
Thumping noise from rear bmw325ise 3-Series (E36) 3 10-23-2005 10:04 AM
Looking for a 4:10 rear end crazy91318 3-Series (E21, E30) 5 09-26-2005 09:49 PM
Rear Road Noise, Noise Gets Lauder As You Go Faste victorgallas 3-Series (E36) 17 01-29-2005 04:05 PM
