| Pads are a piece of cake. Just be sure when you compress the piston for the new pads that you go very slowly when pushing it back in. Before changing those pads, at least inspect the pad thickness. Being the fronts were changed and the light has come on again it may have something to do with the fronts that were jsut replaced. Not always, but in some cases, once that light comes on, the sensor should be replaced. |
