RE: Tune Up - BMW Forum - BimmerWerkz.com
Old 03-16-2009, 07:17 AM   #1 (permalink)
babygurl718 is on a distinguished road
RE: Tune Up
Hey fellow bimmer drivers. I am writing today because i am looking to do a tune up on my 1992 325is bmw it has 123,000 miles on it. i was looking for the ignition wires at auto zone but the guy there told me that my car does not have wires that it just has coils. I am a lil confused so please can some one make this clear to me on what i do need for this tune up because i thought i need ignition wires and not just coils. If there are any suggestions on what i should change with this tune up let me know. You guys are the best
Tiffa
babygurl718 is offline   Reply With Quote
Old 03-16-2009, 10:49 AM   #2 (permalink)
basrite's Avatar
Car: 1995 BMW 320i, 17inch M3 mags
basrite is on a distinguished road
Tiffa,
BMW adopted a new design for sparking early on.
Instead of using a distributor and a single coil to spark each plug, they developed a system to place a coil above each plug. The computer then triggers each coil pack when needed to create the spark.
This helps in two ways... The first is there are less moving parts and things to adjust (distributor, rotor arms, hall effect sensors). The second aspect means the computer can control precisely the timing and create greater sparks by having less distance between the coil and the plug.
You may benefit by replacing the coil packs as yours would be rather old. If its not misfiring.. i wouldn't bother! They are rather costly.
Before replacing the coil packs, i'd check for oil in the wells as the gaskets can fail and leak into there causing misfires.. plus smell and smoke.
A general tune up consists of the following: oil, oil filter, air filter, plugs. Past that you go to coolant, transmissions oils, brakes and fluids. Do these and it should be pretty cool
J.
Yes... i'm a total car nut! Why else would I upgrade my mower to rev to twice its standard rpm!
basrite is offline   Reply With Quote
Old 03-16-2009, 12:45 PM   #3 (permalink)
drz
master of his domain
drz's Avatar
Car: zhp
If you do need new coils, you can buy them from any of several different sites:
- autohausaz.com
- bavauto.com
- pelicanparts.com
and some others.
Turkey Fleet Bond Holder
Old 03-16-2009, 07:01 PM   #4 (permalink)
jmo69's Avatar
Car: 1998 328is 2003 325xi
jmo69 is on a distinguished road
I'd only add one thing to Basrites list, fuel filter.
Cosmos schwartz metalic Sparco strut brace factory X-brace 55w 6000k HID w/LED angel eyes smoked Lamin-X blacked out sidemarkers,tails and brakelights. DDM smoked corners and pedals. 35% tint all around, Prosport water temp and oil pressure gauges, Home Depot lip, M3 rear diffuser ASC-T delete.
jmo69 is offline   Reply With Quote
Old 03-19-2009, 08:15 AM   #5 (permalink)
Thumbs up
Thanks for all the information guys, you guys have been realling informative and i will be doing the tune up over the weekend.
Old 03-19-2009, 10:13 AM   #6 (permalink)
my car is red
94BMW325i's Avatar
Car: 94 325i, 84 325e
Fuel filter is a pain to do on earlier model e36's.
Old 04-15-2009, 03:15 AM   #7 (permalink)
Car: 1993 316i E36
TexasBoy is on a distinguished road
Send a message via Yahoo to TexasBoy
I will vouch for that.....I just tried to change mine at the house on my '93 and it was a pain in the A*#. I found a shop that let me use thier lift and it took 15 minutes that way.
Sean
TexasBoy is offline   Reply With Quote
Old 04-16-2009, 01:11 PM   #8 (permalink)
Peter23 is on a distinguished road
look here my friend!
BMW E36 DIY (Do It Yourself)
Peter23 is offline   Reply With Quote
Do I Need A Tune Up? barrett9699 3-Series (E46, E90) 3 06-30-2005 10:02 PM
Tune-up Bunny Capricorn 5-Series (E12,E28, E34, E39, E60) 1 04-11-2005 02:41 PM
Tune Up?? Cruzin 323is 3-Series (E36) 14 02-02-2005 02:48 PM
Tune Up fast 6 Driving Tales 8 10-13-2004 11:57 AM
Tune-Up? abemcclellan 3-Series (E36) 1 09-08-2004 05:20 PM
