Rattling Noise From Wheel Area - BMW Forum - BimmerWerkz.com
Old 05-09-2005, 08:42 AM   #1 (permalink)
GatorInSC is an unknown quantity at this point
I have a loud rattling noise that comes from my left rear wheel area when I go over bumps or rough areas in the road. The rougher the road the louder the rattle, but mysteriously the rattle disappears if I have the brakes pressed even slightly. Does anyone have any speculation as to what this might be? I can't imagine what would cause it not to happen if the brakes are applied. Thanks in advance! I have a 1994 325ic.
GatorInSC is offline   Reply With Quote
Old 05-09-2005, 11:21 AM   #2 (permalink)
RexKing86's Avatar
Car: 2006 Mitsubishi Lancer Evolution MR
RexKing86 is an unknown quantity at this point
Send a message via AIM to RexKing86
I have a '97 328i, and im having a similar rattle. But this is only when i het bumps. I think it could by the old shooks, but i friend with a 94 318ic said it could be the strut mount? Does anyone know?
used
RexKing86 is offline   Reply With Quote
Old 05-09-2005, 11:41 AM   #3 (permalink)
zlac109 is an unknown quantity at this point
ok your problem is the caliper that hold the brake pads. Normally they should fit really thight and not move. I used to have the same problem. It is nothing critical, don't worry, nothing will fall out or anything. The noise is very annoying though i must admit.
If you wanna buy new calipers, it can turn out to be quite expensive. Over here in england they are 150 pounds a piece, so about 600 bux for both sides.
What i suggest you do is take out the brake pads. You will see some thin metal brackes on theonside that go into a hole in the caliper. Just make those a bit wider by hand and put some heat resistant grease around the corners.
That is what i did and everything is fine now there is no rattling at all anymore.
Another thing you can do, but i do not reccomend this one is just to put a welding spot on both sides of the caliper where the pads are suppose to lean on, it will create tha half a millimeter you need to stop the rattle.
Hope this helps
zlac109 is offline   Reply With Quote
Steering wheel noise on 325xi on right turn rms 3-Series (E46, E90) 1 10-10-2005 11:19 PM
Rattling Noise in the Morning Lainey 3-Series (E46, E90) 2 10-06-2005 12:25 PM
Popping Noise When I Turn Wheel Or Go Over Bumps BMW-ATI 3-Series (E36) 7 07-06-2005 12:43 PM
Strange Noise Form Wheel Area DeathMetal 3-Series (E21, E30) 5 01-19-2005 10:57 AM
Rattling noise under hood coolhuh 3-Series (E36) 2 07-15-2004 10:24 PM
