Radiators Water - BMW Forum - BimmerWerkz.com
Old 03-16-2005, 08:58 AM   #1 (permalink)
aboualmeer is an unknown quantity at this point
hay guys i have a 320i 1991 6cylinder ...
i noticed a decrease in the radiator water in a way that i have to add about half a liter of water every week is this normal cause my engine is very big and fast its ubnormal and there is something wrong ..
and where the water goes AS STEAMM !! DUHh
and one more thing that ive never faced over heated engine u know but am afraid that this water loss could increase and i loose my engine
aboualmeer is offline   Reply With Quote
Old 03-16-2005, 09:39 AM   #2 (permalink)
njtech is an unknown quantity at this point
[snapback]312625[/snapback]
water leaks are not normal. Check for loose hose clamps, pin hole in any hoses, cracked radiator necks, cracked t-stat housing, leaking water pump, leaking heater core.
njtech is offline   Reply With Quote
Old 03-16-2005, 10:28 AM   #3 (permalink)
kyle_baker's Avatar
kyle_baker is an unknown quantity at this point
Send a message via AIM to kyle_baker Send a message via MSN to kyle_baker Send a message via Yahoo to kyle_baker Send a message via Skype™ to kyle_baker
there is a product out that you can put in your radiator that stops leaks, i have heard both praises and curses on this however, your leaks sounds like it might be too much for this product, but if its helps any, you could try and findout, who knows? it might plug that leak right up. good luck
kyle_baker is offline   Reply With Quote
Old 03-16-2005, 11:05 PM   #4 (permalink)
mostwired is an unknown quantity at this point
Try this product. These are great and received good reviews - I used them on a few cars successfully:
http://www.barsproducts.com/index1.html
However - you need to find where your leak is first. Maybe it's not a radiator leak, but a crack in a coolant container neck. I'd take the car to a mechanic for inspection first.
mostwired is offline   Reply With Quote
Coolant precision0904 3-Series (E36) 12 02-09-2011 10:15 PM
Coolant Question dvmotorsports 3-Series (E36) 6 06-10-2005 09:31 PM
Leaky Water pump or the Themostat Housing RedBeemer95 3-Series (E36) 12 08-21-2004 07:13 PM
Water in my car!!! Tknojnky 3-Series (E46, E90) 14 01-21-2004 07:43 PM
