Radiator Leaking Need Help! - BMW Forum - BimmerWerkz.com
Old 02-07-2005, 07:09 PM   #1 (permalink)
jroberts312 is an unknown quantity at this point
Need some guidance. On sunday, (right before the bowl) my radiator starting leaking. At first I thought it was a hose. After removing parts to see better it appears it is coming from just below the expansion tank. It is leaking between the expansion and where it attaches. Can this be repaired? It is a 4cylinder car. The dealer said I could just replace the expansion tank. The service manual says it is integrated. Does anyone know?
jroberts312 is offline   Reply With Quote
Old 02-08-2005, 01:26 PM   #2 (permalink)
Super Moderator
dutchbmw's Avatar
As far as I know the expansion tank is integrated in the radiator. Did you ask the BMW dealership or just an allround carshop for their opinions?
BMW '96 M3 (SOLD)
June 2005 Car Of The Month!
Originally Posted by Torque
Old 02-08-2005, 02:30 PM   #3 (permalink)
Shudogg's Avatar
Shudogg is an unknown quantity at this point
there is a blue plug down there and that might be the cause...the expansion tank is sold seperately...that leds me to believe that one can replace it.
i would:
take rad off completely
run some water through it with a hose
locate the leak that way
then check all fittings and connections
<span style='color:red'>
CLASSIFIED</span>
<span style='color:blue'><a href='http://www.whiplashdvd.com' target='_blank'>WHIPLASHDVD.COM</a></span>
Shudogg is offline   Reply With Quote
Old 02-08-2005, 05:48 PM   #4 (permalink)
jkh2828 is an unknown quantity at this point
Sorry for the hijack...
Is getting coolant all over the pullies and lower engine block bad when you change out the thermostat? Or does it just make them squeel a bit, and then burn off?
As for your case - I think it is one unit because I've heard if you break off connections on the top side, you need a new rad, not just the tank - but I could be totally wrong.
<img src='http://www.jbheiss.com/pics/BMW.jpg' border='0' alt='user posted image' />
jkh2828 is offline   Reply With Quote
Help! Help! Help! dvmotorsports 3-Series (E36) 6 06-02-2005 12:51 AM
Need Help! Car Is Barely Drivable komodo 3-Series (E36) 79 03-26-2005 10:41 AM
Help! My a/c will not turn on! jroberts312 3-Series (E36) 7 05-28-2004 03:30 PM
clutch master cylinder help! imprttuner88 3-Series (E21, E30) 1 02-05-2004 10:04 PM
2001-2003 M3 Steering. Need Help!? BMWPro77 3-Series (E46, E90) 6 01-31-2004 07:22 PM
