| Radiator Filling Process I put in a new water pump and radiator. Now I need to refill the system. Is there anything special I need to do? I filled up the reservoir, but that seems like it is not going to be enough fluid for the whole system.
I did check the Bentley manual but did not find anything about refill process (other than the air bleed process)
Thanks! |
