Quik oil change question - BMW Forum - BimmerWerkz.com
post #1 of 12 (permalink) Old 07-21-2004, 04:17 PM Thread Starter
I only have the factory jack, and don't have the room to store a set of jack stands, or ramps. Is it possible to jack up the car using the factory side mounted jack, and reach the oil drain plug? If so, what side should I lift up? Where exactly is the plug? Is it facing the front side(s) or rear.
I'd much rather crawl in the dirt and change my own oil, than pay some ass clown $35 to do it for me.
wulley1 is offline
post #2 of 12 (permalink) Old 07-21-2004, 04:30 PM
Kevin325i's Avatar
You don't even need to jack it up. It's a stretch, but if you lie on your back and crawl up under the the passenger side from the front you can reach it with a wrech and back the plug out. Or if you need a little extra room drive the car up on a couple 2x4s to get an extra inch or two.
Kevin
Kevin (President TBEA)
Kevin325i is offline
post #3 of 12 (permalink) Old 07-21-2004, 05:10 PM Thread Starter
Thanks for the help!!! I'll probably jack the car up anyways, just for the extra room.
wulley1 is offline
post #4 of 12 (permalink) Old 07-21-2004, 05:23 PM
Defector
El Presidente's Avatar
Never get under a car supported by a jack. If you don't have room for jackstands, find a freind and borrow some. It is far too unsafe to change the oil using just the factory jack.
El Presidente is offline
post #5 of 12 (permalink) Old 07-21-2004, 05:24 PM
350z
and the oil plg is on the passenger side on the side of the oil pan!
David
bigred318 is offline
post #6 of 12 (permalink) Old 07-21-2004, 07:03 PM
kestrel325is's Avatar
kestrel325is is an unknown quantity at this point
This is very true.
One time, I had to do a brake job on my ex's Stanza, and I jacked up the front of the car (not thinking that it was a FF) and the floor jack and the car started running away from me!! Stupid, I know.
kestrel325is is offline
post #7 of 12 (permalink) Old 07-21-2004, 09:56 PM
get a set of
keep them under your bed, under the sink, burried in the yard with a map to get to them later, attic, or in your trunk somepace. there is always room for jackstands.... I don't have a set but they are not huge by any means. ramps now there isn't always room for those.
2008 128i Jetblack
007ben is offline
post #8 of 12 (permalink) Old 07-21-2004, 10:41 PM
You should also use some blocks of wood and jam them right behind the rear tires before jacking the car up. Even with the E-brake enguaged, you want to make sure the car doesn't roll off the jackstands.
I agree with everything said. It's too dangerous to get under a car which isn't properly supported. Don't take chances with your life.
Bry
<a href='
target='_blank'>- VIEW MY MODS AND PICS</a>
<a href='
target='_blank'>- PARTS FOR SALE</a>
&lt;img src=&quot;
Autotechnica is offline
post #9 of 12 (permalink) Old 08-19-2004, 12:39 AM
StanfordKid is an unknown quantity at this point
Could somebody post a picture of the drain plug? I'm working on a '94 325 for a friend. I change the oil on all my other cars, but for the life of me, I can't find the drain plug on this one!
Thanks!
StanfordKid is offline
post #10 of 12 (permalink) Old 08-19-2004, 12:54 AM
Defector
Its the only pic of my underside i could find. Anyway, you can just barely see it. If you look at the slanted ribbed things in the center of the pic right before the underside drops out of view, those are the fins on the oil pan. The drain bolt is to the left.
post #11 of 12 (permalink) Old 08-19-2004, 01:20 AM
Power Shifting
Cruzin 323is's Avatar
ya, definately would never get under a car on just a jack!!
-SOLD..
*UPDATED 8.25.06*
R.I.P Fast 6
Cruzin 323is is offline
post #12 of 12 (permalink) Old 08-19-2004, 10:49 AM
nycbmw325is is an unknown quantity at this point
here is a picture of the complete oil pan. you should be able locate the oil pan since it is HUGE. the drain plug is part number 7 in the diagram, it is located on the passenger side of the oil pan very close to the bottom (but still on the side)
nycbmw325is is offline
New User Quik Question heftylefty 3-Series (E46, E90) 0 04-10-2005 11:00 AM
New BMW owner with oil change question... kevandju 3-Series (E36) 10 07-16-2004 10:39 PM
Oil Change Question Frozenwave 1,6,7,8 - Series and Mini Cooper 2 03-10-2004 11:49 PM
Question about oil change Braymond 3-Series (E46, E90) 1 02-10-2004 09:35 PM
Question about change the plastic impeller alienbust 3-Series (E36) 6 01-03-2004 02:08 PM
