question on differential - BMW Forum - BimmerWerkz.com
post #1 of 12 (permalink) Old 01-05-2009, 07:12 PM Thread Starter
fabcal's Avatar
fabcal is on a distinguished road
I have a question: I changed the differential in my 325, the one I put makes the car quicker now but I don't have top speed anymore, I can only reach 210 km/h. My question is, is there a chip for my transmission that can change the ratio without having to open the transmission itself. I have a manual transmission by the way.
fabcal is offline
post #2 of 12 (permalink) Old 01-06-2009, 03:26 AM
bimmerguy82's Avatar
bimmerguy82 has a reputation beyond repute bimmerguy82 has a reputation beyond repute bimmerguy82 has a reputation beyond repute bimmerguy82 has a reputation beyond repute bimmerguy82 has a reputation beyond repute bimmerguy82 has a reputation beyond repute bimmerguy82 has a reputation beyond repute bimmerguy82 has a reputation beyond repute bimmerguy82 has a reputation beyond repute bimmerguy82 has a reputation beyond repute bimmerguy82 has a reputation beyond repute
nope. you changed the final gear ratio which will lower your top speed. What diff did you put in? the only way to get your top speed back is to change to a less aggressive ratio.
BMWcrazy
___________
-Joshua
BMWCCA member#407674
bimmerguy82 is offline
post #3 of 12 (permalink) Old 01-06-2009, 05:22 PM
318ise36318is is on a distinguished road
i bet u put a 318is diff on aint you! gives u hell of a lot on pull off but nuffin top end! that diff will just snap on you! get it off put ur 325i back on ASAP
318ise36318is is offline
post #4 of 12 (permalink) Old 01-07-2009, 08:05 PM Thread Starter
fabcal's Avatar
aight, thanks a lot for the advice
fabcal is offline
post #5 of 12 (permalink) Old 01-07-2009, 09:28 PM
Pandemonium Director
nukeduster's Avatar
nukeduster has a reputation beyond repute nukeduster has a reputation beyond repute nukeduster has a reputation beyond repute nukeduster has a reputation beyond repute nukeduster has a reputation beyond repute nukeduster has a reputation beyond repute nukeduster has a reputation beyond repute nukeduster has a reputation beyond repute nukeduster has a reputation beyond repute nukeduster has a reputation beyond repute nukeduster has a reputation beyond repute
the e36 diffs regardless to gearing are all rated at the same torque handling. the main differences are the input drive flange bolt arrangements and if its LSD or not.
youre just hurting your fuel economy by having a numerically higher rear end. You'd need to be in the neighborhood of 500+ft/lbs of torque before you need to start worrying about killing an e36 diff.
nukeduster is offline
post #6 of 12 (permalink) Old 01-07-2009, 09:36 PM
my car is red
94BMW325i's Avatar
94BMW325i has much to be proud of 94BMW325i has much to be proud of 94BMW325i has much to be proud of 94BMW325i has much to be proud of 94BMW325i has much to be proud of 94BMW325i has much to be proud of 94BMW325i has much to be proud of 94BMW325i has much to be proud of 94BMW325i has much to be proud of 94BMW325i has much to be proud of
did you put in a 3.91 from an automatic 325 or something? Wondering what diff you put in your car.
94BMW325i is offline
post #7 of 12 (permalink) Old 01-08-2009, 03:38 AM
webeclassics is on a distinguished road
sound like the diff you put in was out of an automatic. 4:10 vs 3:73 There is nothing you can to regain your top speed short of changing the diff again.
I have a diff with 3:73's do you want to some trading?
Dave
webeclassics is offline
post #8 of 12 (permalink) Old 01-08-2009, 08:35 AM Thread Starter
fabcal's Avatar
the one I put is a 3:40 from a 95 M3, I guess I should've also changed the transmission.
fabcal is offline
post #9 of 12 (permalink) Old 01-08-2009, 10:07 AM
nukeduster's Avatar
The 95 m3 has a 3.15. The 95 automatic was a 3.23. They probably just told you that it was off an M car to sell you the part. Check the diff, there should be a tag on it (usually hanging off the drain plug if it didnt break off) with something like "3.73" or "S4.10" etc..
Changing the transmission at the same time isnt a magical fix to make your car faster. You did the correct thing, You went with a numerically higher rear end to get more speed out of the power you had available to you. BTW, when do you ever have a need to go faster then 210kph(130mph) anyway? The top speed limiter on your car is set from the factory to limit your car to 230kph.. even with a different diff you're not going to go much faster than your current 210.
post #10 of 12 (permalink) Old 01-08-2009, 10:21 AM Thread Starter
fabcal's Avatar
Ok, thanks Nukeduster, but what I mean is that I red line on 5th gear at 210 and I feel like the car can take much more, don't forget I have a complete exhaust system from Dinan, a cold air intake and a performance chip also from Dinan.
fabcal is offline
post #11 of 12 (permalink) Old 01-09-2009, 10:28 PM
nukeduster's Avatar
If you want higher top speed get a numerically lower diff. You can get as low as 2.79 rear ends for e36's without going custom. This WILL kill your acceleration, and I'd only recommend something that low if you are forced induction of some sort. A 3.15 is about as low as I'd go with any naturally aspirated e36, it'll top out at roughly 160-167mph(270kph) depending on which transmission (zf or getrag) your car has and if it has sufficient top end power.
With my stock ZF S5D 310Z transmission in my 95 m3 with a chip i've hit an indicated 165mph with the stock 3.15 rear end.
A 3.46 is a good combo to get if you can find one, it accelerates a noticeable amount quicker than stock but will still top out at around 130-140mph(225kph) at redline.
YMMV.
post #12 of 12 (permalink) Old 01-18-2009, 07:37 AM
garbone's Avatar
garbone is on a distinguished road
Send a message via Yahoo to garbone
YMMV.
x2
garbone is offline
Shudogg i need you "Differential Question" nobrakese36 3-Series (E36) 3 01-27-2006 03:07 PM
Differential Question nobrakese36 3-Series (E36) 2 12-21-2005 09:28 PM
Differential... Ljk619 3-Series (E36) 1 10-09-2005 06:09 PM
Differential Question... jrhaile 3-Series (E36) 7 05-31-2004 08:22 PM
differential viali8 3-Series (E21, E30) 0 04-24-2004 06:56 PM
